Camshaft Research and Question
Do you have stock gearing? I do, and my car at stock redline (6400rpm) is good for 109mph in third gear.
Autocross runs are almost always done in second gear, with no shifting. As such, they tend to emphasize flexible engine performance with wide power bands. Again, even with BFG Rival S tires, I usually can't use WOT coming out of corners in second gear. If I had a TPI intake, it would just be harder to manage traction at low rpms. OTOH, the ability to pull hard to near redline is helpful for the faster parts of courses. I spent years racing at TPI-equipped 92 Camaro in a stock class. If I had ever moved to a class that allowed different intakes, a short-runner intake is the first mod I would have done! And in my experience, whatever is good for autocross runs is also good for street driving: the most flexible engine possible, that requires the least shifting to get good performance.
My gearing is stock @ 3.33. That's not "bad" enough to swap higher IMO. At least, haven't felt it a priority. If you consider 90mph the top-end "requirement" for my 3rd gear (ZF6), maybe it will make sense why I was thinking a mega-ported TPI would pull the hardest for the practical limitations I set for myself/car.
In reality, my top-end landed lower than I hoped. That's one reason I might try the HSR. Before I do that, I need to pull the sidepipes and see how that dynos out. It might just be my exhaust.
Regarding the auto-crosser who tried an HSR then went back, it probably did have to do with the class he wanted to race in. With a TPI, he was probably able to race in 300rwhp class? (350ci with a hotcam). Obviously a largetube intake is still an intake swap so I'm not sure it had to do with the kind/number of modifications? That's why I'm thinking it had more to do with hp. IIRC, he won quite often in the lower hp class that the TPI would allow. With the HSR, competition was a lot higher.
FYI, there is a very rare superram intake that was designed for LT1 engines, that would also help you.
I have a nagging feeling about my LT1 intake, OR TPIS miniram copy. This intake IS optimized for higher end RPM performance, yet is it still worth it to find an intake that is optimized for the RPM band that I am trying to achieve? I keep bouncing back and fourth between my stock LT1 and how to use a TPI intake, to port it out fully to expand it's airflow and torque curve YET taking away from the off idle torque. I know this is an elaborate "balancing" game of components, so my head is spinning on how best to pursue this.
The TPI intake with it's artificial "supercharger effect" from 2000 to 3000 RPM and then power drop off at 4000 RPM has me wondering about fuel efficiency as well. It is a headache when I think about it and look things up and still find myself with more questions to ask and plenty of pissed of guys on this forum.
When he wanted an LT1 longtube intake, I pointed him to a recent sale auction listing for one that didn't seem to sell. Do you think he attempted to see if it was still for sale? NO
He just wants to talk and talk and talk .... and does so in circles. He sounds coherent for a couple of days, then drugs must intervene.
At the earliest stages of conversation, I pleaded for him to revisit his goals and what he wanted. Take some time and drive a few cars (from TPI to LSx)....then decide FOR SURE what he wants. Do you think he did that? You should have SURE he was about a TPI -- while IGNORING the eBay unit. You should have read how he complained that he'd NEVER be able to find another...while ignoring THAT one.
He's got the intensity and focus of a 3-yr-old learning about the world. And... his project window went from 2...to 3 yrs. I think it's fine when someone wants to learn...or just talk. This guy doesn't seem honest about it. Plus, he's living in multiple forums and playing issues/facts against each other. Not what I'd consider .... especially for someone without near-term, realistic intentions to build.
With regards to that intake you mentioned, I am not going to throw down $1000+ dollars on something when I need that money for college and while I am unemployed. That would be a smart investment on my end so soon into this on-off research I am doing in my spare time or when I need a break from school work.
What point is there for me to drive in a TPI motor car and an LS motor car when I am focused on improving my LT1 motor car and I want it to behave like a TPI motor? I told you, engine swapping is out of the question and I would rather dump money on modifying the block that I already have and that my PCM and wiring already exist for in my car.
When I have guys pushing me away from pursuing a TPI intake, yeah, you will find me with circular comments! Just when I thought I should keep my LT1 intake, I find some reason to consider an intake that will help me capitalize on my shifted torque curve which is why I should not give up on the TPI intake. Furthermore, I don't do drugs and I don't even drink anymore. So knock off the b.s. Greg. Your comment here is quite misleading and strays from my actual comments in this thread and my other two. Are you the one intoxicated on something?
I am going to need those three years or whenever to research diligently and understand the lingo in order to piece together a collection of parts for my LT1 motor that will help give me the performance that I am seeking. I can't thank GrumpyVette enough for his website.
http://garage.grumpysperformance.com...ith-tpi.10494/
https://www.corvetteforum.com/forums...rformance.html
https://www.corvetteforum.com/forums...e-runners.html
B.S. Dude...you don't have a clue yet.
Driving cars helps you understand how different intakes, technologies, and cars FOCUSED on various RPMs perform. That's a no-brainer I think any "college student" should be able to understand. With more focus on learning, maybe you'll "get there" some day.
Congrats on your first day of being sober! Welcome back!!!!
I am NOT the only one that things you are all over the map. They SAY one of every four people has a mental issue. Look around...if the other seem normal.....
Like I said....1 in 4. Look around!
FWIW guy (who should be studying more for good grades), I recently dated a woman who needed some cold-hard sit-down "discussions" to learn better relationship skills. I tried and tried and tried to explain how some VERY bad parenting affected SOME of her social skills. Finally, I gave up. Then....I found something from Bill Murray that explained my frustration with her.
I DID MAKE AN EFFORT TO CORRECT MY MISTAKE BY ADMITTING I SCREWED UP ON POSTING THAT GRAPH! I was at campus and "taking a break from school work" by quickly google searching for ZZ4 motor or ZZ4 camshaft torque curves and that graph was what popped up. What can I say? Nothing, because your goal now is to totally try to discredit me and I still can't figure out what the hell for! Lost business of some kind in my efforts? Making aware to the readers the options they have that don't revolve around high horsepower power production?
You always burn more fuel in the cold, I am not sure tuning can help this fact and you spend more time idling in city traffic and your motor needs to work harder to propel your iced up and snow covered car in deep snow. And, I throw weights in the back of my hatchback so I burn a little more fuel. This is where the stroker motor may be a bad idea and why a regular change of camshaft with higher lift and shorter duration will balance my power with fuel efficiency. Again, I need to talk with the camshaft maker and I need to do my research and fine tune my knowledge of how the camshaft works for what my goal is.
2. claims to have owned this car 10 years
3. claims to have been laughed off other forums
4. claims to drive car in winter
5. claims to want less power
6. claims to want LTR intake on hit lt1 motor
7. claims to plan on buying super fuels
8. claim people are picking on him
9. claims UI checks
Since you haven't taken any of my other suggestions seriously, try THIS one: Assuming you really want to know "where the serious Gregg went".
Read back through your last three threads and tell us how you managed to alienate multiple people in each thread. It will be a learning experience for you. We can call it a college assignment. No...extra credit.
Since you have three years, no pressure on completion date either.
Good luck!
PS. I'll add to Polo's list...
9. claims UI checks
- Wants to CHOKE motor at 3k rpms then REALLY CHOKE it by 4500.
- Wants maximum torque UNTIL 4500 rpms.
- Worried about mpg (cost) but wants to use expensive high octane fuel.
- Will save fuel by programming for less use during decel.
- Can't modify/cut hood...but maybe he can after all.
- Thinks cutting down and modifying TPI (in addition to his hood) is better idea than a stroker kit.
- Wants to cut down TPI even though LONG TUBES is what he wants for TORQUE!!!
- Believes "snow float" on fat tires is best approach to winter.
- Too cheap to buy beater for snow but willing to modify custom intake to fit under hood.
- Doesn't think a stroker is a good idea -- even though INSTANT torque is his goal. Why? (cost, mileage, safety, etc...)
- Doesn't like gears to create overall bump in torque because it'll make him drive in higher rpms
- HATES high rpms
- Wants better performance in 6th gear on hwy and FOR SURE doesn't want to hurt hwy efficiency
- Trolls for cam to meet these requirements then asks another forum to explain why WE are feeding HIM bullshit with L31 stump puller cam.
- Wants to ask us multiple questions per day but can't take the time to post correct, valid graphs/link to support conversation.
That's all I can think of RIGHT OFF THE TOP OF MY HEAD!!!
Care to amend ANYTHING you've said?
Last edited by GREGGPENN; Nov 18, 2017 at 12:16 AM. Reason: Forgot the MOST important goal....6th gear!!!
Good luck!
- HATES high rpms
I hate to read through all of it again to ind out if the part about lowering the engine to make the intake fit was his idea or someone else...Maybe he can write a summary of what he has learned from his last 3-4 threads here about his lt1 build.
What is the other forum? I feel like I am missing out on something. It's like a tv show character you find funny you want to see their other works.
Did anybody mention the l98 cam specs or l98 motor swap to him?
10.5 1965 comp rpot 'HR
232-23334-240 Ex 1110
HSR ported and macthcints
zz9 cam 1.5 rocker
aafr 190 or 1905 CC
matchin youe to intekae
Headres w/cats/ your call
Your car wleipp wipp til 6k with its stick geeratar
Youllbe nin love . Forever............turssstu me on ethis
id you nwed aony porntung workinf done,.,,,, i geve amone y bac guaratenn no. Think about it.
