Camshaft Research and Question
700c 70cc .028 gaskwt youlll bejuzt fuein,
Keepp yoor ifin comcig in slcow wo 200 with a omdrern cominberussterbcahcner you ulllsill if IOD on the st,
Dont kitsne to hard and fast runes,.
Let ius know whw aaata you erooryt back.
When qaA kis rhwew qa is 84 tryingto malke it as a DDD...he hepst alomst teh G gmueveve and asnsa car run fgraeutu
i c i X x hihallitituee EF I wi ituunve int tifor what rot sor mogts? camn e thyat nncghharder than en EFOI. GVVp ahgpaade Whnpowho estedd ebovvveee 80088 enyoneewawat
10.5 1965 comp rpot 'HR
232-23334-240 Ex 1110
HSR ported and macthcints
zz9 cam 1.5 rocker
aafr 190 or 1905 CC
matchin youe to intekae
Headres w/cats/ your call
Your car wleipp wipp til 6k with its stick geeratar
Youllbe nin love . Forever............turssstu me on ethis
id you nwed aony porntung workinf done,.,,,, i geve amone y bac guaratenn no. Think about it.
Now you are speaking the op's language.
Since I have plenty of time to screw with my motor, I should see if simple tweaks such as camshaft advancing and having 1.7 RRs thrown on, would make me happy, before going hog wild with my other ideas.
Also, I apologize for my comments putting down the L31 camshaft proposal you made at the start of this thread. I only recently started looking into the B-Body LT1 camshaft and that was when I noticed the specs are nearly identical to the L31. Plus, if I have my heart set on making a TPI intake work on my LT1, the B-Body LT1 camshaft would be the best complimentary camshaft.
When the spring comes around and I get a chance to feel the full power of my motor up to 5000 RPM on the expressway, I will still be soul searching as to whether or not this is what I want to do. How can I pass up instant low end torque on demand though?!
Penix........you are still here...........
I have found if you tighten all o2 sensors.....IT WILL FEEL FASTER AND RUN BETTER!
I will cut my old TPI intake down for you to get that good ol low end torque for you now that the o2 sensors are tight....I also have my old cam for the L98 for you!........when the spring time comes, you will have an awesome f-body!!!!!! I agree......how can you pass this up???
Just so you know, I didn't install those oxygen sensors myself two years ago, that was another shop. I have regretted the work they did ever since.
You don't need to cut up the TPI intake. After some additional measuring, I have 3 inches exact of clearance between the top of my stock intake to the bottommost portion of the wiper cowl above. The stock TPI intake should fit without the need to make additional room, but I will need the custom shop to make that decision after a test fit. If I were to try to use a FIRST TPI intake, I might definitely run into clearance issues since the plenum is that much more beefier than the stock plenum. It don't matter anyways because I don't need that much airflow, extrude honing a stock TPI intake with AS&M big runners should be all the airflow I need for my given set-up.
It doesn't matter if you're really doing this or just trolling us. If you want a slower Corvette than you have stock, using an intake that goes back in time to a design that was specifically made as a workaround to relatively poor engine and emissions management systems and that was less efficient overall than the stock LT1 you have now...well, that's your choice. Just quit expecting anyone else to agree that it's a good idea. Same goes for your ridiculous drivel about isobutylactopropacannabinoidyzine and any other silly alternative fuels you want to fantasize about.
Honestly, I don't care what your opinions are about what I am doing. My car is a daily driver that I don't take to the track and one that I am actively driving in the winter. So, if I am making my car "slower", it is for good reason, it is a daily driver, not a damn race car! Do you understand that at all? I understand you specialize in making high horsepower race cars, that is fine but it is not what I am trying to do for my car! So, if you have any true expertise, tell me how I am making my car slower with my intended modifications? Please refrain from using your own personal opinions and insults as factual information.
My intent isn't to rub in what I originally said....my point is that I knew what I was talking about, gave good advice and you responded by doing the same thing to me that you're doing now, to Matt.
Matt knows what he's talking about. Listen to him.
This is why I keep on asking for opinions, but so far it is not very helpful when all I get is mocked for it. You build your car your way and I will build it my way, but give me the knowledge I need to make better choices in the future. That is all I ask.
And one big reason that you don't know that is that you've been driving around in a broken car. A good-running LT1 Camaro has no problem breaking normal street tires loose from a standing start. So moving "torque" lower in the powerband gets you nothing but more wheel spin.
Dammit, I'm already going back down the rabbit hole with you. I'm sure you'll reply and tell me why none of that applies to you.
