Fuel Pump
Old Nov 12, 2017 | 11:41 PM
aklim's Avatar
aklim
Originally Posted by Mishawaka
Yep, that's a pulsator, exactly what I replaced. You think replacing it with a section of submersible hose would be better? Many seem to do it.
I just figured fresh wiring or even a new sending unit would add to reliability.
AFAIK, the old pumps needed a pulsator but the newer style, which we have does NOT. Considering that the pulsator is slipped on and is more likely to have fuel flowing past the rubber that a hose with clamps, I would think that it is better from the standpoint that the damper is not needed and we are removing a failure point.
It could in the long run but I don't like to simply replace stuff when I am in the midst of diagnosis. It adds variables to the equation. Unneeded variables. If you had to drop the tank, I'd agree with you but this is so simple, let's fix the car first then decide if we need to. IF you were doing a cam, sure, we can change lifters since we are there and don't want to tear apart the engine. There is little prophylactic value to this at the moment.
Old Nov 12, 2017 | 11:56 PM
Mishawaka's Avatar
Mishawaka
True, I just ordered the pump and will wait on deciding a new harness or sending unit. Thanks!
Old Nov 13, 2017 | 08:12 AM
vader86's Avatar
vader86
Do not expect any further instructions from Racetronix, they rarely give you anything about the installation.
They will recommend (if you ever talk to one of them) that you replace the pulsator with a piece of hose and two clamps, but that instruction is not with their kit. The kits are basically a few packets of parts in a box and no instruction.
If I were you, I'd go ahead and upgrade the in-tank wiring assembly when I ordered any kit. There wont be any instructions with that either though.
Old Nov 16, 2017 | 05:36 PM
playsdixie's Avatar
playsdixie
just a question, I just replaced my fuel pump and just like last time 5 years ago, I had to do it again because a line slipped out of the pulsator...neglected to do it last time, but I just put in a new pump and it has happened again...no pressure but I can hear the pump running...going to eliminate the pulsator, but what size hose would you need?
Old Nov 16, 2017 | 05:41 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
Originally Posted by playsdixie
just a question, i just replaced my fuel pump and just like last time 5 years ago, i had to do it again because a line slipped out of the pulsator...neglected to do it last time, but i just put in a new pump and it has happened again...no pressure but i can hear the pump running...going to eliminate the pulsator, but what size hose would you need?
lose the pulsator when using walbro or racetronix pumps!!!
5/16" I.D. hose with SS clamps
Old Nov 16, 2017 | 06:57 PM
aklim's Avatar
aklim
Doesn't that hose HAVE TO BE fuel submersible rated and not just any old fuel hose?
Old Nov 16, 2017 | 07:00 PM
aklim's Avatar
aklim
Pump and kit: http://www.racetronix.biz/customkiti...c=FPA-009H&eq=
Hose, gasket, bolts and everything you need to just replace the pulsator: http://www.racetronix.biz/itemdesc.a...IK-004&eq=&Tp=
Old Nov 16, 2017 | 08:02 PM
playsdixie's Avatar
playsdixie
wow....can't beat that set up....that's a really good deal
Old Nov 16, 2017 | 08:23 PM
aklim's Avatar
aklim
I'm just too lazy to chase all around town to find the right stuff.
Old Nov 17, 2017 | 10:54 PM
scotth48's Avatar
scotth48
All the parts including the hose and clamps to use to replace the pulsator. Larger gauge wiring harness for inside the tank. I had both a 195l and a 255l on hand. I used the 195l as engine is stock.
Old Nov 18, 2017 | 02:25 AM
Mishawaka's Avatar
Mishawaka
Are you talking about the bulkhead kit or the wiring they send with the kit?
http://www.racetronix.biz/itemdesc.a...WA-C44&eq=&Tp=
Old Nov 18, 2017 | 06:08 AM
playsdixie's Avatar
playsdixie
I just ordered the kit from racetronics....30 bucks....i'll let you know how it is.....
Old Nov 18, 2017 | 08:40 AM
  #33
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Racetronix the BEST and cannot go wrong ! Some IG stuff on my website !
Old Nov 18, 2017 | 03:40 PM
  #34
vader86's Avatar
vader86
Both, I have both installed.
Old Nov 18, 2017 | 07:50 PM
  #35
Dt86's Avatar
Dt86
Just an FYI, when I replaced my bad stock fuel pump the new delco fuel pump came with the fuel hose to use in place of the pulsator.
Old Nov 22, 2017 | 04:40 PM
  #36
scotth48's Avatar
scotth48
Bought it back in 2011 pump and installation
kit # PIK-005
