From: Las Vegas - Just stop perpetuating myths please.
You want a wide LSA like at least 112 to work well with the computer. Search a dynamic compression ratio calculator you can use to select a cam with the duration to match your desired dynamic compression ratio.
You are making this to difficult unless you want someone else here to do all the math for you. You built the motor and your calculations will only be as good as the static compression ratio you measured - if you bothered to do so. No one else can magically determine you head chamber volumes and the above piston volumes included the gasket compressed height.
Or well you can take best guesses from the faceless internet all day long. Good luck with that.
Would a 108 lsa be more streetable?I don't want to have to use a stall and a 12:20 car is all i want.
If all you want is a 12.20 car.... then sell the HSR, put on some ASM long tube runners or a used superram intake, put a tight 2400 rpm converter, hence streetability will be docile..... you could run the LPE 211 or 219 cam, both very friendly and on a 112lsa..... your car would drive smooth and pleasant no matter the situation.
And quite frankly, you'd probably still run in the 11's.
good luck with whatever direction you go in.
I have been out of the racing scene for 20 years and decided i need the speed.HSR stands for?I have 2 motors that just need to be machined and put together...350 flat top motor with 6" rods and a 408 flat top with 6" rods.I want to be able to cruise 30 miles without problems and have street racing power.Any help is mucho appreciated
Beach Bum - you are still around? I haven't seen you post in ages.
My old screen name was AKS Racing and you used to offer advice when I was in the deep 10s. Assuming you moved on to bigger and better vettes judging by your pic.
thanks cardo0, measured .022 deck height, ring gaps avg .014-.016, 4.030 bore, 3.75 stroke, 64cc, 210cc, calculator 10:7-1 cr, .030 head gaskets .0020 mains, .0030 cam to rod clearance with oe base circle and .500 lift @ 1.,5rr degree wheel and push rod geometry next week. I actually love the math but i know racers are The source of Knowledge on great setups. OCD but ok with it. ps: for dirttracker: HSR "holley stealth ram" OCD "obsessive compulsive disorder" lol;: laughing out loud.
That helps but there is no information on the piston valve relief's or dish or done. And head chamber volumes can vary alot from advertised. Best method is to measure both the head chamber and above piston volumes with liquid.
Next step would be to find a dynamic c.r. calculator that you can use. Expecting someone else to crunch the numbers for you on the faceless internet is begging for error. Now you could ask someone to verify your choice and discuss how to determined what you got. Myself I don't have that much free time and wouldn't try it even if paid to do it as I just have more interesting things to do.
My 383 has 11.2 to 1 compression, LE 2 heads, Lunati cam 231*/239* duration .571"/.589" lift, A4 trans, 3400 stall, 4.10 gears and lousy Nitto tires but still runs 11.70s all day even with a ridiculously poor 1.9 second 60 foot time. Better tires and better driving should give me 11.30s or better. That said, she is still very easy to drive on the street.
ok, got the math just looking for cam suggestions please thank you
Just finishing short block torque and clearance specs tonight. Building heads and intake next weekend.
Cam clearance on stroker rods should be ok under .600 lift but have not found cam.
here is my exact setup on summit compression calculator. not sure if it is static or dynamic ?
C4 of Year Winner (appearance mods) 2019
Wow....a 1/4m track racer recommending long tubes. Wonders never cease!
And here I was thinking of pulling my mega-ported semi-siamesed SLP runners in lieu of an HSR!!!
Street-only 383 application with a 6-sp, AFR 195's, and SR cam.
What are the SR cam specs? It is not often that you hear of someone running a solid roller cam with long tube runner TPI set-up. This is a first for me.
Originally Posted by Street89vette
Just finishing short block torque and clearance specs tonight.....
Camshaft :??? xfi280? Lpe219? xfi292? any suggestions appreciated
Well when I use Summit's c.r. calculator using your specs I get 10.74 static c.r.! That's quite a difference. And what I've been trying to say is that since you have the block on the table/stand you could get very accurate volume measurements (using liquid) instead of using published specs that can be unreliable.
If you must I suggest a simple dynamic calculator to try several different cam profiles for the dynamic c.r. that you want. I found this calculator by United Engine Machine that looks to be as simple as it gets: https://www.uempistons.com/index.php...3c8dd514d00dd2
An 89 isn't solid roller. Did I miss something? Looked again and didn't see "solid" listed in this thread until your post.
I hope the link works for you. Good luck.
yes, re-calculated and used the one on your link... works better. Are you using water or oil or special gel for the cc measuring? finished short block tonight and mock build to check intake ports matching. start cutting hsr down to fit under hood next week. LPE219 really as good as forum says?
moroso pan hits against oil pickup... 8.25 pan... 8.25 pickup. lol
I use alcohol with food coloring in it. If you can find 1/4" plexiglass you can make your own cover and drill a hole with a nice wide chamfer on it. I'm still using the plexiglass plate I bought decades ago and I think it was a Comp Cams kit but you can find the graduated (ml) cylinder on line. I asked the pharmacist at Target for some graduated syringes (no needle) and got a handful of 5cc for free.
I use petrol jelly to seal the plexiglass and a thick grease to seal the crivece between piston and cylinder wall. Don't expect everything to seal w/o bubbles the first try. Keep working with it until you get it where you can repeat it accurately. Clean parts should be easier to work with than used parts. Here's a link to my camaro's LT1 liquid measurements with pix: https://camaroforums.com/forum/lt1-l...mes-ccd-81437/
That HSR looks pretty bad azz and your motor is looking great to. Almost to good looking to install and run . I would hate to get that one dirty.
I think you will have alot of self satisfaction once you get it done.
BTW I need to ask what are the holes on the back of the HSR plenum for? As far as I know the HSR doesn't have EGR provision. But what else can bolt on there??
