Headlights blinking
Old Mar 17, 2018 | 07:15 AM
Chris Millikan's Avatar
Chris Millikan
1st Gear
Default Headlights blinking
I have a 1948 Chevy truck that I put an LT1 out of a totaled 91 corvette in it. It has a painless wiring harness with factory computer and mostly factory wiring. My headlights have started blinking on and off. I don’t believe it’s a loose wire because it does it sitting still in the driveway with the engine not even running. It has to be some kind of voltage issue but I don’t know what to check. It’s been working fine but now it seems like as soon as they’ve been on a while something warms up and it starts acting up. Thanks for any help
Old Mar 17, 2018 | 08:42 AM
Churchkey's Avatar
Churchkey
Stock headlight switch? HL switch has a circuit breaker built into it your issue is common when the switch circuit breaker gets weak / fails.
If the lights draw to much current when using high wattage H4's etc the switch circuit breaker will trip/reset. If this is the case you will need 2 relays for the headlights.
Good luck
Old Mar 17, 2018 | 09:20 AM
WVZR-1's Avatar
WVZR-1
Good luck
This relay configuration when coupled with proper wiring will/should certainly improve the lighting also. Nearly everyone could benefit from rewiring headlamp circuits using relays!!
Old Mar 17, 2018 | 09:44 AM
ghoastrider1's Avatar
ghoastrider1
hadthe same problem in my old 67 ford pick up. Was the headlight light switch.
Old Mar 18, 2018 | 10:58 AM
fredk's Avatar
fredk
Just to let u know the LT1 came out in 92.
To Headlights blinking
