Dead Opti?
Old May 30, 2018 | 11:36 AM
  #61
Macvipersd's Avatar
Macvipersd
Cruising
Originally Posted by Tom400CFI
That's a new one for me. I don't know if you can salvage the connector. It's possible...depending on condition, I suppose.
To test the opti, simply plug the 4 pin "opti harness" into the distributor, take your coil wire (connected to the coil) and position the opti end of the wire near ground -like I had done in my video. Turn the ignition ON, then spin the distributor...it should throw a good spark(s).
update:
turns out connector not issue, although I will add a dab of epoxy to better secure it, once I pulled opti apart....as you would expect, full of rust. Cap and rotor good, tin plate completely rusted, drive plate had all kinds of rust in 360 slots and rust everywhere. Also plate “wavey”. Was able to “re-flatten” plate after a few tries by pressing between to pieces of flat metal w visegrips and heating to 300*. Soaked tin plate in cider overnight. Going back together after I soak in baking soda and water and spray light coat of WD40. Will rtv any suspect areas so NO MOISTURE will get in. Thanks for help. I am having a hard time finding part numbers/parts for h20 and opti drive seals?
thanks again for your help
Old May 30, 2018 | 11:42 AM
  #62
vette196's Avatar
vette196
Originally Posted by Macvipersd
update:
I would reach out to the opti doctor, he has an account and is very good with answering questions
Old May 30, 2018 | 12:02 PM
  #63
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
update:
Make sure that you run kleenex through the sensor so as to clean the lenses, before reassembly.
Old May 30, 2018 | 02:02 PM
  #64
Macvipersd's Avatar
Macvipersd
Cruising
Default H16
cant find opti doctor in this forum, how do I find him?
Old May 30, 2018 | 02:06 PM
  #65
vette196's Avatar
vette196
optisparksolutions@gmail.com
Old May 30, 2018 | 05:53 PM
  #66
Macvipersd's Avatar
Macvipersd
Cruising
Default H16
does the rotor go on one way? Dowel in opti drive plate towards rotor tip or 180*
Are there supposed to be seals for plastic cover and cap? It had a silicone grease on it for a seal.
mine is unvented, thoughts?
special tool for drive seal in timing cover?
Old May 30, 2018 | 08:15 PM
  #67
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I can't help you much on this post;
I can't remember,
I don't recall any seals
Venting is better, but mine's not vented either.
There is a special tool. I've not changed my seal yet. It doesn't leak, so...
Old May 31, 2018 | 12:50 PM
  #68
jvettman's Avatar
jvettman
The rotor only goes on one way...there are two screws and a dowel on the rotor. There is suppose to be a ruber o-ring seal on the cap, not the plastic cover. I would not use grease on any parts in the Opti, it can make its way to the sensor. You can look up what the "special tool" for the drive seal looks like (a screw and vice grips). Please for the love of all that is Corvette, locktite the rotor screws.
Good luck!
Old May 31, 2018 | 07:50 PM
  #69
Macvipersd's Avatar
Macvipersd
Cruising
Default H16
Good luck!
ok so my original issue was shut down/ no start after getting to temp. Recent water pump got opti wet inside. No moisture found but a lot of rust. I cleaned and reassembled but when I plug opti into connector and turn shaft, it’s not throwing spark from coil wire. My low res (black wire) has 5v key on and no change in volts while turning shaft. High res (next one) pulses around 2.5v while turning. Yellow (3rd) has 12.5v+ and the last .03v
what should I see? Shouldn’t low res be 1.2 ish while turning. Does this test indicate bad sensor?
i was very careful inside.
Old Jun 1, 2018 | 10:24 AM
  #70
Macvipersd's Avatar
Macvipersd
Cruising
Default H16
what should I see? Shouldn’t low res be 1.2v ish while turning. Does this test indicate bad sensor?
Old Jun 3, 2018 | 12:17 AM
  #71
jvettman's Avatar
jvettman
I had a number of no-start/stall conditions on my 94 and it seemed like it would change...I would fix one and it would die again. I changed a ton of stuff, but these were the problems that I verified were plaguing me:
1. The opti was installed wrong and would periodically die, this was because one of the rotor screws was flying around inside with the washer causing trouble AND there was oil on the sensor.
2. The coil was after market (red but not MSD) and it was cracked. When it heated up, it would stop working.
3. The fuel pressure regulator had a ruptured diaphragm (failed to hold vacuum), it would sometimes cut fuel pressure, then reset and work fine.
Again, this was not everything I changed, but these were the things I verified were bad. Its hard to diagnose a stall or no start on these cars because so many things can cause it...in fact multiple things can cause it at once. Don't give up!
Old Jun 5, 2018 | 10:52 AM
  #72
64Scout's Avatar
64Scout
I was hoping there would be some resolution to this. I'm having a no start condition and am reading as many Opti threads as I can.
Old Jun 5, 2018 | 10:57 AM
  #73
jvettman's Avatar
jvettman
The point to my post was there is no silver bullet for a no start or stall condition, there can be many causes, you need to do some troubleshooting and provide that information to these forums. People here can help you pin it down, but often it will not be easy. My problems happened to include an opti, but it could just as easily been a fuel filter...or coil...or ignition module...or a broken fuel gauge (as in tank it empty). What symptoms are you seeing and what troubleshooting have you done?
Old Jun 5, 2018 | 01:50 PM
  #74
64Scout's Avatar
64Scout
This is why I would have liked to read about the fix, so I can look at the different things and figure it out without a lot of forum posting. Reading posts by others who have fixed the issues gives also me something to do at work while I don't have anything to do.
I've got a thread here already, but the nuts and bolts of it involves wide open throttle, a 1-2 shift (a4) and engine shutdown. Fuses checked out ok. (The ones on the passenger side dash) no new codes. Fuel pressure about 43psi. I haven't been able to have someone turn the key while I check for spark, but I shot some ether in the TB and nothing. Tach reads zero during cranking, Torque app shows no data for rpm. Fuel pump runs for 10-15 seconds rather than the 2-3 its supposed to. Car is a 96 lt1.
Right now I'm in the middle of moving and don't have any time to diagnose it further.
Old Jun 6, 2018 | 06:48 AM
  #75
1stVetteFinally's Avatar
1stVetteFinally
my issue (I'm the OP), seems to be with the ICM, not the Opti. I'm looking at possibly having to move next month, so I don't have any money or time to work on the car right now.
