high side valve core replace
Old Jun 24, 2018 | 08:35 PM
barchetta1's Avatar
barchetta1
Default high side valve core replace
It looks like the low side can be done with a core removal tool that lets you remove without removing r134a but the high side I cant figure out.. can it be replaced somehow without doing a refrigerant recovery? Looks like its hard to get to or maybe its my imagination.
Old Jun 25, 2018 | 02:48 PM
belairbrian's Avatar
belairbrian
I have a Mastercool 81490 which is designed for both the low and high side.
Is the issue that you don't think your tool will fit?
Old Jun 25, 2018 | 03:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vette? Does the hi-side valve have a short r12->r134a adapter?
Sounds like you have the short adapter which puts the Schrader ~1/2" down inside the fitting.
I'm in the middle of the 134a changeover and confused whether to use the long or the short hi-side adapter. Sorry to not hi-jack your thread.
Old Jun 25, 2018 | 07:34 PM
barchetta1's Avatar
barchetta1
Mine is a 96 so came with r134a but the high side doesnt look like the core is serviceable.
High side
Low side
High side
Low side
Old Jun 25, 2018 | 08:23 PM
belairbrian
Just my thought, I'm certainly no expert.
I would expect all the fittings to be the same from car to car. Otherwise the servicing fittings on the service equipment would have to be changed out between cars.
If that is true then any tool that can do the high side should work.
The only way it would not work would be if the shaft in the tool can't reach the valve. And if it can't reach your no worse for trying.
Old Jun 25, 2018 | 08:39 PM
65Z01's Avatar
65Z01
How far down is the Schrader in the hi-side port?
FYI: Amazon has a Schrader valve removal tool (Mastercool 81490) with 13mm or 16mm reach.
Old Jun 26, 2018 | 04:08 PM
barchetta1's Avatar
barchetta1
Originally Posted by ihatebarkingdogs
There is no Schrader valve in the high side port. It is a flapper valve of some sort. It is not serviceable. I had to replace the entire liquid line on my 88, but the part was still available from GM at the time. I had no idea the R-134 ports were the same deal as the earlier ports. Now I do. Put a new o-ring in the seal cap, screw the cap on tight, and add refrigerant from time to time. Probably all you can do.
EDIT/ADD: Remove the liquid line from the car and have the leaking port TIG welded shut. In the future, use one of the high-side switch ports if you really need to connect to the high side for diagnostics. I never connect to the high side on my C4 because I don't want to disturb that jankey 30 year old port valve and cause a leak that I can't get parts to fix.
Its my low side that is leaking.. I was going to replace the high side proactively,.
Old Jun 26, 2018 | 06:53 PM
barchetta1's Avatar
barchetta1
All righty then. If the high side isn't leaking, obviously leave it alone because it can't be serviced. I own a core removal tool for the -4 R-12 fittings and it works OK most of the time, but can be fussy if there isn't much pressure in the system to blow the core up into the tool. The tool probably costs more than the R-134 that will be lost if you don't use the tool. And no fussiness.
I have an r-22 tool that once I get my adpaters to adapt to 134a should work good. I hope.
I'll post result because an r-22/r410 tool is very handy.
To high side valve core replace
