Exhaust note question please
Old Aug 1, 2018 | 05:39 AM
barchetta1's Avatar
barchetta1
Originally Posted by 84 4+3
very mild cam comparable to a stock 89 l98 cam. 206/214 on a 112 lsa iirc. Nothing worth noting. Still has mufflers, they're just built into the tips there. They are a chambered (basically glasspack) type. The old monza style muffler is what they are modeled after. Mid america sells them and I love them.
As far as drone, top off or on it doesn't bother me. Lugging it around 1600 gets a little and running it up past 3k gets some too but just cruising I only really hear wind noise. Way better than the 3rd gen my cousin has or the 67. I found it not really any worse than the stock type muffler they replaced. There is a crossover tube on the rear y though. Top on it is dead quiet... like surprised me how quiet. The nice thing is the tips protrude out under the bumper. Iirc that helps as well as turndowns.
I heard the cam.
L98 is a better sounding motor than the lt1. Ive read that many times. thank you for the videos.. great sound..
Old Aug 1, 2018 | 11:16 AM
84 4+3's Avatar
84 4+3
Originally Posted by barchetta1
I heard the cam.
This is a cam.
mine was a stock replacement really, look up the specs of an 89 l98. I believe the first year of the lt1 shares the same profile. It's been a while.
Old Aug 1, 2018 | 06:20 PM
barchetta1's Avatar
barchetta1
Well, I could hear it at idle. At least it sounded like a cam to me
Im starting to get that idea based on lots of listening that xover pipe is part of my recipe.
Old Aug 2, 2018 | 12:54 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
When I hear the newer mustangs and camaros I hear each cylinder fire, its very defined. In my 96 its muddy and nothing defined.
Im wondering, whats creating this sort of mixed sound? If I went with "performance" catalytic converters would it help? Or is it the stock resonance muffler that mixes it up?
do you guys know what I mean?
I know what you mean. I BET, that I've put MORE TIME INTO THIS CRAP than everyone who's posted on this thread, combined.
I did it specifically to eliminate the individual cylinder firing sound (like an old V8 boat, IMO) that my C6 exhibited. I TOTALLY FAILED in my mission at the time, but set out to do the same thing with my 'Vette Kart project and feel that I totally succeeded. A "curvey" exhaust dramatically reduces that individual cylinder firing sound, leaving what I consider to be a "delicious, bubbly" V8 exhaust sound. So, straight piping with minimal bends helps with what you want, I believe.
Quicker and more attainable however is to retard your ignition timing at idle. The more you retard it, the more you'll hear the individual cylinders firing. It works and the effect is dramatic.
Old Aug 2, 2018 | 05:36 AM
barchetta1's Avatar
barchetta1
I cant wait to try this tonight!
Very interesting.. so the sound from the 70's engines we hear is essentially destroyed by what I bet is super high ignition timing at idle for emissions.
Old Aug 2, 2018 | 10:00 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
IDK. I'm not sure that I'd call '90's engines' ignition timing "super advanced". I'd guess it's similar to base timing in '70's motors, but not sure the general specs by decade.
I had a theory that the timing on my LS2 was quite retarded for emissions reasons...but someone in that exhaust threat that I linked above (IIRC) claimed that base timing is around 12*...IDK if that's true or accurate or not...the exhaust doesn't sound that way to me, but maybe.
Old Aug 2, 2018 | 10:43 AM
84 4+3's Avatar
84 4+3
According to my tech 2, the lq4 in the Sierra (6.0l) idles with the timing around 16 degrees. I wouldn't think a high perf ls2 would be much different... Who knows though.
Old Aug 2, 2018 | 11:35 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It could be. IDK. Sure sounds like a SBC w/the distributor cranked way back.
BLAAAA_BLAAAA_BLAAAA_BLAAAA
Old Aug 2, 2018 | 12:04 PM
84 4+3's Avatar
84 4+3
I think the valve train geometry has a lot to do with it.
Old Aug 2, 2018 | 12:41 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yeah....I'm stuck on exhaust shape. In the thread I linked it's all explained out over the thread...but you look at other cars that had the LS2....exact same engine, yet they sound much better (IMO)...certainly much different than the LS2 does in the C6. Why? The only diff is the exhaust shape (routing). In the GTO, and CTS-V, the exhaust system has way more bends in it, and they sound better/different/good. I applied that theory to my 'Vette Kart exhaust and it was totally successful. It sounded like poo with the stock Y pipe into a 2.5" straight through Magnaflow....now it sounds delicious with a bendy exhaust and two straight through muffs.
Old Aug 2, 2018 | 12:58 PM
84 4+3's Avatar
84 4+3
The bends promote mixing, so you won't have as defined of an exhaust pulse which would explain the more burble you get. Your vette kart does sound really good btw. I'm fairly happy with how mine sounds too. It has the tone I'm looking for. Again it is very subjective. The 67 is about at straight as it gets... 3 inch at the collector straight back to magnaflow straight through mufflers with offset outlets but center in... or maybe the other way around. I forget. That's also an entirely different animal though. I've come to enjoy the sound of headers pinging though.
Old Aug 2, 2018 | 12:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Both these cars are LS2's (same heads/valve geometry) but have quite different sounds:
Mine: "Blaaaa-blaaaa-blaaaa-blaaaa-
His: La la la la la la la....Mmmmm
Old Aug 2, 2018 | 01:10 PM
  #33
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I believe that you're totally right about this. When I was doing my exhaust-ive research (ha ha), I found images of a Jeep Grand Cherokee SRT, exhaust, which has what I consider to be "extra bends that have no purpose at all"....other than for sound:
Old Aug 2, 2018 | 01:27 PM
  #34
84 4+3's Avatar
84 4+3
https://youtu.be/7FyktHczjI0
https://youtu.be/07jWp-jzQUs
My God I forgot how bad C6s sound. My cousin has a third gen. Iirc you seemed to get the right sound on that too. At around the 1:16 mark that is what the car presently sounds like. It's a little much for my taste imo.
Old Aug 2, 2018 | 01:38 PM
  #35
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I know it. It's not good.
That GTA is a bit much....I agree with you. But my god, that is a gorgeous car!
Old Aug 2, 2018 | 02:52 PM
  #36
84 4+3's Avatar
84 4+3
yea, when you get past the cracked spoiler, zero clear coat and all the dents it ain't bad looking.
Old Aug 2, 2018 | 08:10 PM
  #37
barchetta1's Avatar
barchetta1
When I look at my "main spark advance vs. MAP kpa it looks like at 85f it idles at 800rpm and shoots for around 31 degrees advance.. does that seem right?
To Exhaust note question please
Old Aug 2, 2018 | 11:55 PM
  #38
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No. That is way, way too far advanced for that engine speed. 18 is the most *I* have ever seen and that was on a low compression, aluminum headed SBC with a 234/244 cam.
Actual advance at idle should be ~12*-~15*, IMO.
Did you try retarding the bejeezus out of it to see how it changes the sound?
Old Aug 3, 2018 | 05:21 AM
  #39
barchetta1's Avatar
barchetta1
No my damn DST tuner interface is on the fritz again. I hate that thing, Sometimes it lights up and works sometimes it doesnt.
Old Aug 5, 2018 | 02:05 PM
  #40
barchetta1's Avatar
barchetta1
Ok my tuner started working again. I tried lowering my idle advance all the way down to zero and I didnt notice a thing. So then I read some stuff on the interwebs and the recommendation was to lower the idle so I lowered to 550rpm.. It gave it a nice burble sound, nothing like a cam but it started to hunt just a little so Id have to tune that out if I decided to go that route.
I will try playing some more with advance.. maybe raise it even. I cant seem to retard it passed 0.
