Adding Power Seat Tracks
Old Oct 23, 2002 | 01:14 PM
Siveck's Avatar
Siveck
Default Adding Power Seat Tracks
I'm installing power seat tracks in my '89 along with the switches in the console. I haven't taken the console apart yet, I haven't even gotten the switches or tracks yet, but they arrive in the mail tomorrow. I'm anticipating the problems I will have. From what I can tell, the switches come with a harness to the seat and power leads. Is there already an existing harness in the console that I can just plug into or am I going to have to run power from somewhere. The car has no power seats currently. If I need to run power, then where from and what amp fuse do I need? has anyone out there done this conversion? As far as mounting the switches, I guess I can cut the holes out- you can see where the holes should be. And the bracket that hols the switches in, I'l; make something because GM has discontinued this part. Any suggestions on the wiring?
Old Oct 23, 2002 | 02:10 PM
BLUE ONE's Avatar
BLUE ONE
Default Re: Adding Power Seat Tracks (Siveck)
I would be interested in how much the power and non power seat tracks weigh if you could find the time to do that and post it please :D
If there is a big difference i might take those non power tracks off you if we can agree on a price plus shipping :smash:
:cheers:
Old Oct 23, 2002 | 02:12 PM
bogus's Avatar
bogus
thats an interesting question.
I would suspect, with consideration to cost control, that GM used 1 harness for every car.
you may have to add a fuse thought...
could be interesting.
Old Oct 23, 2002 | 02:29 PM
Siveck's Avatar
Siveck
Default Re: Adding Power Seat Tracks (BLUE ONE)
According to UPS, manual tracks shipped: 8.34lbs and power track+ wiring and switches: 17 lbs. This is for one side. So you would lose about 8.5 lbs with the downgrade. I don't have the manual tracks anymore as I swapped them for the power ones. :)
Old Oct 23, 2002 | 04:28 PM
BLUE ONE's Avatar
BLUE ONE
Thanks i will look out for some cheap manual racks over here.
:cheers:
Old Oct 23, 2002 | 06:26 PM
Kendall's Avatar
Kendall
I'm needing a switch. Where did you get yours and @ what cost. I can't find anyone selling them for less than $100.
Old Oct 24, 2002 | 02:30 PM
Siveck's Avatar
Siveck
Default Re: Adding Power Seat Tracks (Kendall)
My switch was free, it came with the power tracks which I swapped my manual ones for - EVEN swap. :eek:
Old Oct 28, 2002 | 10:57 AM
Siveck's Avatar
Siveck
There is a power plug. I cut the holes for the switches out by drilling three 5/8" holes on each side of the console depression, and filed the front and rear holes square with a triangle file. The seats are much more comfortable now that there are more adjustments. :)
To Adding Power Seat Tracks
