I posted earlier in another thread I was having problems at the drag strip as soon as I would launch car it would fall on its face about 10 ft out. Gas gauge showed half a tank, well the gas gauge was off and the problem was fuel sloshing to the rear of the tank. Now with full tank having a pretty good Friday night
Reason: Add Photos
Nice; was that just from a cam swap or did you do get the 1.6 rockers too? I forgot.......109mph roughly not too shabby. Nice 60 foots......drag radials??
Yes I do have Lunati Voodoo 1.6 S/A RR, Lunati double valve springs and CC hardened pushrods. this was on street tires. 275/40-18 Summitomo HTRZ 2, I do have a Protorque 2800 converter. leaving at 2500rpm
Reason: update
I like your plate, I am in Canada and wanted 1nastyC4. They said I couldn't have it because c4 is an explosive. You're very close to my setup and my best run was 12.2@115.
Atco as I understand it is a fast track and well prepped generally.... still salty that Etown is closed although an insider said it may come back. I doubt it.
