Idleing problems
Old Nov 25, 2018 | 06:03 PM
383vett's Avatar
383vett
Is your timing correct? If the motor is retarded, it will retard even further after putting it in gear possibly causing it to die.
Old Nov 25, 2018 | 06:12 PM
aklim's Avatar
aklim
Originally Posted by kitttransam
yes I did adjust the idle by the iac counts already. I have it in the 20-30 range. But I’m still having the same problem. I honestly think something is not right. I had some minor stalling problems awhile back but it was only happening after starting the the and putting in drive too soon. I’m breaking out the fsm and going to start going through the diagnosis chart for stalling.
How is the desired idle speed? Could it be too low for the cam?
Old Nov 25, 2018 | 06:13 PM
kitttransam's Avatar
kitttransam
timing is at 6. I did check that.
Old Nov 25, 2018 | 06:15 PM
kitttransam
Question about the evap canister. Is all the crap from inside supposed to come out the bottom port??
Old Nov 25, 2018 | 06:16 PM
kitttransam
Well I capped everything going to the evap and tried it out. Still does the same problem. Scratch that. Tried again and now it stumbles a little and motor stays running.
Old Nov 25, 2018 | 06:48 PM
kitttransam
[QUOTE=aklim;1598393365]How is the desired idle speed? Could it be too low for the cam?[/QUOTE
my Idle speed that I had set before was higher than stock. I want to say I had it at 750 up to temp. I have the lingenfelter 211 cam FYI.
Old Nov 25, 2018 | 07:18 PM
kitttransam
I think I read somewhere that someone had a problem with the superram sealing at the runner for the egr port and it caused problems. I’m really thinking about pulling this thing apart. I have 2 sets of superram gaskets so I might pull the plug and rip it apart.
Old Nov 25, 2018 | 09:22 PM
aklim's Avatar
aklim
Have you tried ether on the possible leak spots
Old Nov 25, 2018 | 09:39 PM
kitttransam
Well I sprayed carb cleaner everywhere and did not hear any change in the engine. But I think I do have an egr problem. Finally had a reason to buy a vacuum pump tester. My egr is not holding vacuum at all. So either something happened to the hose or the valve is bad. Can’t tell with the big pizza box covering it. So I guess I’ll be pulling the super ram plenum to check it out.
Old Nov 25, 2018 | 09:48 PM
aklim's Avatar
aklim
Since you are doing the tuning, why not eliminate the code 32 and be done with it all?
Old Nov 25, 2018 | 09:55 PM
kitttransam
i would love to ditch the egr all together but guess what I live in stupid California. I had one fail last year because the egr was not getting vacuum. Of course fixed that at the time. And barely passed. I’m only running one cat ditched the precats for my smog legal headers.
Old Nov 26, 2018 | 12:31 PM
kitttransam
Well got this sucker apart. Looks like bad egr valve won’t hold vacuum. Also from what I was reading I should have a negative backpressure egr. Well this one is a positive and it’s not original.
Old Nov 26, 2018 | 09:38 PM
  #33
kitttransam
Well the egr did need to be replaced anyway. But guess what problem still persist. I know the highest I had my idle set for was 750. Well I said screw it. I set it for 850 and now it doesn’t die. I guess the 211 cam is a little more radical than I thought.
