Jet Chip
Old Jun 14, 2019 | 09:18 PM
c B's Avatar
c B
Default Jet Chip
I found this jet chip in my parts car. Not sure if it even works. Should I check it out and see what it does? Do yall think it's any good or woth checking g out? I've not been a fan of cookie cutter chips but don't know anything about this one.
Old Jun 14, 2019 | 10:27 PM
aklim's Avatar
aklim
I doubt it would be worth the time wasted to put it in the ECM much less test it.
Old Jun 18, 2019 | 10:02 AM
KyleF's Avatar
KyleF
Throw it in the garbage.
Maybe use it for target practice?
Could you do a craft with it?
Put it on a stick and use it as a back scratcher?
Whatever you do, don't waste your time putting it in your car. You will get more enjoyment out of a fresh coat of tire shine.
Old Jun 18, 2019 | 05:04 PM
tequilaboy's Avatar
tequilaboy
https://jetchip.com/shop/chips-modul...ansmission-35/
Might be interesting to read the chip to see the actual programming, but I'd be suspicious of the advertised gains. Also appears to have a socket, so could be used as an adaptor for use with a custom eprom or emulator. I'd say its worth about $25.
Old Jun 19, 2019 | 08:44 AM
bjankuski's Avatar
bjankuski
Try it, it only takes a few minutes and it may do something, the chip you have is the stage 2. You can always go back.
It is a G1 adapter which means it plugs into the computer and your stock chip pugs in on the side. Both chips are used the jet chip runs the engine programming and the factory chip takes care of the limp home features.
Old Jun 19, 2019 | 04:59 PM
vader86's Avatar
vader86
I'd hold onto it as a spare in case theres a problem one day, or you need it reflashed itself to play with.
To Jet Chip
