Renegade Intake
While I’m on my wish list we need a 300hp crossfire kit or at least parts list. Recommend or supplied heads, CAM, Renegade, EBL ECM with a canned tune from Rbob and machined TBs. Lots of people on here ask how to get 300hp from a crossfire and it’s a realistic target for a streetable car. Could have a separate set of recommendations for a 383 all backed by actual tests.
Ask Fred from NZ how my motor sounds, I fired it up while he was at the house. Ask him if it sounds like a mild CF. LOL (grin
) Last edited by Buccaneer; Sep 27, 2019 at 07:19 PM.
I was able to take a real close look at my recent purchase and I think its a keeper!
I will be doing heads, cam, valve train, fuel pump, headers so the Renegade will get some help. This should be a great start. The bad thing is I wanted to document on paper what I'm starting with. Some track times, dyno, etc. Proof of where I came from giving me something for my upgrades to compare with. Of course I'd have to do it again after mods are complete. A fully documented, proof is in the pudding BUILD! If I were to guess, I'd say stock out the factory was 205hp a quick 15% loss takes me to 175 to the wheels. Next, factor in age, I think I'm looking at about a 150-160hp car. Not the most impressive start, but every journey starts with the first step.
I am looking forward to my progress through all this, but that I will post in my build thread.
Tom400CFI: Yeah, it will depend on a lot of things actually, but I do need to put the TBs on a flow bench and see where I'm at first regardless which ones I use unfortunately to feed a 421. If things work out well, I WILL surpass Ben for sure whcih after talking with him recently, he thinks he can get his 84 into the high 11s which would be awesome N/A. I would hope to see 10.7ish or maybe a little higher... as long as the rest of the car will take the abuse as it sits today. I hope to find out.
anyway you can read all about my journey and see what applies in your case. I tried not to over capitalize so e street heads, flat tappet cam etc. EBL flash II ECM and a WBO2 sensor to help with the tuning.
Unless it was real cost prohibitive Id run one.
If youve seen the way the lsx fast runners are shaped those are a winner. Making them totally accesible for those that port a bonus
Also, just got back from the WFO and as soon as I mentioned a 421 to the machinist he was ready to start machining today. "Hold up doood...I don't even have a block yet." LOL He said I'll order a SHP block for you today and get it at a discount price. It all sounded good, but I really want to plan this motor out, lots of things to consider on this build if I decide to go forward and lots of cash since I would be getting everything new including heads as well, either Brodix or AFR. So another motor from top to bottom would be new just like the motor that is currently in the 82. While there he also pulled out a NOS system that he said we should put in it since he loves NOS and runs it on everything he owns and knows his stuff when it comes to setting that kind of thing up. The point would be... Well, actually there wouldn't be any point doing that if I were to go CF again on the motor since anybody can throw a bottle at a motor and make it run. I want to see what I can do with just TBs. I know it may sound crazy, but oh well.
And one last thing...The machinist also said that a tripower TB setup on the Renegade would be badass and I should do that first and then we talked a bit about that all while I was comparing it and using his new motor as a reference that has four TBs on top a large plunum somewhat like the CF manifold with over 900 CI sitting there on the stand ready to go into his race car this weekend. Oh what an awesome site that motor is and will truly be a Beasty thing this season.
I was also taking some dimensions off of a four barrel manfild he had lying around while there.
James...check your PMs.
well clearly it is too complex for EMS
If you got a scratch and dent or come across one (no rush) I may be interested.
Trying to figure a fun build for this l82 I have..thought a carbed crossram would be pretty cool. Holleys would bolt on no?
