Renegade Intake
Old Sep 24, 2019 | 09:15 AM
  #121
BlackVetter's Avatar
BlackVetter
Thanks, I will certainly look into Summit. I spent huge amounts of time reading Grumpys stuff and there was huge amounts of it!! And then one day.....GONE!
OUCH, i never copied anything...sad
Old Sep 24, 2019 | 09:36 AM
  #122
84 4+3's Avatar
84 4+3
Originally Posted by James C4
@84 4+3 My '84 has a full Melrose exhaust system but I don't think it's to 13.8. I would have had to got a good Renegade intake for that.
I don't think intake and exhaust would get a 13.8 either honestly. Slight bump in cam would be close. There are too many 84s I'm trying to keep track of damn it.
Old Sep 24, 2019 | 03:43 PM
  #123
Gibbles's Avatar
Gibbles
Grumpys is still there.
http://garage.grumpysperformance.com/index.php
Old Sep 24, 2019 | 04:07 PM
  #124
BlackVetter
Thanks Gibbles, but if you look, all the material is gone... Zero, not a....
Old Sep 24, 2019 | 04:28 PM
  #125
Gibbles's Avatar
Gibbles
Signed into the forum?
Maybe I'm not looking in the right spot, but i see content.
Old Sep 24, 2019 | 06:18 PM
  #126
GregMartin's Avatar
GregMartin
Originally Posted by BlackVetter
Hello,
This is a great place to be isn't it? Thank you all for taking the time to chime in with a blast of knowledge. I am thinking Renegade. I have followed this intake for a while in this forum as well as others. It really is a great bolt on! I am frustrated reading about all the quality issues. I work in a manufacturing environment and this quality would NEVER pass! So I am at a crossroad, A) I spend the money and get it! Or B) I port an extra one I have. I do live near the Summit location in Ohio. I could stop there and physically look at what they have for stock. Either option has to be done! Poor thing is bound, gagged and barely alive. But...we can fix this. Once again thank you all and hope to share some success soon!
-Nick
Hi Nick
if you can get a good one that’s a better option than porting the old one. But there are plenty of people here who have ported the existing intake and are happy with the results.
Old Sep 24, 2019 | 06:25 PM
  #127
GregMartin's Avatar
GregMartin
Oh and yeah over 50 thousand 84s built so there are still a lot out there and a few here. Hell I know of at least three near me in Brisbane Australia.
Old Sep 24, 2019 | 06:31 PM
  #128
GregMartin's Avatar
GregMartin
I burned a type R in my Colorado. Put about 3 trucks on him because he was sleeping and he never made it back up lol. They're not that fast lol.
First gear in my Colorado is done after about 10 feet. The only things it will beat are mums in people movers and then only if they don’t know it’s a race.
Old Sep 24, 2019 | 08:03 PM
  #129
84 4+3's Avatar
84 4+3
Strange, pretty sure mines faster than the vette.
Old Sep 24, 2019 | 08:19 PM
  #130
MatthewMiller's Avatar
MatthewMiller
Brisbane Australia.
Your avatar is cracking me up.
Old Sep 24, 2019 | 08:36 PM
  #131
GregMartin's Avatar
GregMartin
Old Sep 25, 2019 | 05:02 PM
  #132
BlackVetter
I went to Summit yesterday and looked at a Renegade. It appeared to be decent quality. I was really nervous and excited because I am financially ready to buy it.
Well, today I'm seeing it a little differently and I got my glasses on, haha! (I'm about that age). My biggest areas of concerns are the dizzy hole/bracket hole and there is a hump above where EGR passage is, respectively shown in the pics below.
Q: Can this cause alignment issues installing dizzy? If it is engaged in the oil pump at the bottom, then the camshaft gear, will this hole being slightly off cause binding or unnecessary wear on either.
Q: Can this "hump" be finished flat? Or will I eat into EGR wall too far. I am not running one and I will plate off the top. All the other runners a smooth and flat at bottom with very minimal casting marks.
Any helpful thoughts are appreciative, Thanks!
Old Sep 25, 2019 | 05:11 PM
  #133
James C4's Avatar
James C4
@BlackVetter I'm no expert but I do believe the dizzy hole could be easily fixed by a machinist. Idk about the EGR but overall yours looks a lot better than mine. I probably would have kept mine if it was that close. Just make sure your intake ports line up with the gasket because mine did not.
Old Sep 25, 2019 | 05:47 PM
  #134
BlackVetter
Hi James
I would certainly have no problem taking of that"fin" off, but that fin wouldn't be there if hole was centered. I'm sure there was a point where the program begins to drill. I'm wondering about alignment. Dizzy shaft may be angled if that hole isn't where it's supposed to be.
-Nick
Old Sep 25, 2019 | 06:51 PM
  #135
swamp21's Avatar
swamp21
I think you could clean up the distributor hole with a dremel in about 5 minutes. Still, it's ridiculous to need this "post-processing". This isn't a cheap part!!!!
Old Sep 25, 2019 | 07:10 PM
  #136
BlackVetter
I am no stranger to cleaning things up like, de burring, chamfering edges, chasing threads, and so on. Even mild porting. Fully capable. Issue is more with the darn distributor shaft not being perpendicular to block right above oil pump and cam. I'm not experienced enough to know how much I can get away with.
And the port floors on cylinders 6 and 8? If I grind that hump down, will I be left with a hole? I could always take it back and roll the dice on another one.
On a side note I will say they were very cool with the whole thing. Props to Summit for that!
Old Sep 25, 2019 | 08:14 PM
  #137
GregMartin's Avatar
GregMartin
Do you think the distributor hole is drilled and machined offset? Do you have a standard intake you could take measurements off any sbc intake will do? I guess the only way to know is to put it in and see how it feels lining it up. Maybe if you put assembly grease on the distributor gear and turned the motor over buy hand you could get an idea of how well the teeth meshed. Hopefully someone has a clever way of doing it. Maybe a better way would be to use engineers blue on the distributor gear ( or colour it in with a permanent marker) turn over the motor by hand and see where the teeth make contact.
You also need to make sure there is a bit of end play once the distributor housing is tightened down.
the problem with all this is that you need to do all the work before you know if it will work.
Don't forget to check that the intake gaskets line up properly. I did a couple test assemblies before I started squeezing permatex everywhere. I found that the oil pressure fitting on the rear China wall was in the way so I removed a bit of material from the back of the intake manifold with a dremal and all was well.
i guess if the distributor hole is a long way off you could have the hole tig-ed and re-machined. Hope these suggestions are useful.
To Renegade Intake
Old Sep 25, 2019 | 08:24 PM
  #138
GregMartin's Avatar
GregMartin
Unfortunately I didn’t take a lot of photos of my intake. But from what I can see the machining around the distributor looks the same and I have no issues.
Old Sep 26, 2019 | 08:59 AM
  #139
swamp21's Avatar
swamp21
Just curious, did Summit have any comment on all the quality issues with the Renegade? I'd think there must be some ongoing dialog between them and Eddie on this...
Old Sep 26, 2019 | 11:15 AM
  #140
cv67's Avatar
cv67
St. Jude Donor '05
Buccaneer in the C3 sec helped design this maybe pm him I dont see anything wrnog with it?
If you did grind on it and break through just use some JB quick it will hold fine I do it all the time on heads/intakes holds up great
Or get some Belzona if youre really worried...they fix cracked blocks with that stuff.
