HVAC Trouble Code 9???
Old Sep 12, 2019 | 08:38 AM
Josh Brown's Avatar
Josh Brown
Default HVAC Trouble Code 9???
Ive got a pretty 1989 Corvette, with the climate control digital display HVAC controls. The Ext temp light flashes for the first minute, and nothing works, then after 1 minute, everything works perfectly. Not really a problem just a nuisance.
I read the codes following the instructions, and under the diagnostics number, it came up with code 09.... 09 doesn't come up with any results in all my searches for an 89 model. Any additional guidance is appreciated.
Just for fun I checked the A/C pressures and all looked in spec, and the AC works fine. Im sure its some sensor, but dont know what code 09 points to.
Old Sep 12, 2019 | 02:09 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
09 is "low freon"
Old Sep 12, 2019 | 02:53 PM
Josh Brown's Avatar
Josh Brown
I checked the pressures, and all looked good, and it blows very cold no problem. Could it be just the sensor? Any idea how to test it like what the resistance or voltage should be? Can I disconnect to see if that fixes it?
Old Sep 16, 2019 | 08:11 AM
Josh Brown's Avatar
Josh Brown
No Help?
I thought the trouble code 9, mixed with the not working for 1 minute consistently, then working perfectly would tip someone off that had the problem before.
Old Sep 18, 2019 | 08:08 AM
Josh Brown's Avatar
Josh Brown
One more bump. Still no answer. Im sure its some other sensor, but cant figure it out. Everything works fine after 1 minute, the Ext temp stops blinking, all good.
Old Sep 18, 2019 | 10:09 AM
pcolt94's Avatar
pcolt94
Measuring pressures is the proper way to check first. But it does not tell you how much Freon is in the system and the system operates much different driving compared to standing still and checking.
Code 9 is low Freon. The code is set when the compressor ON time is too short. In other words it is cycling too much. This usually indicates low Freon if everything else is working OK. You might consider adding a few ounces of Freon and see if that makes a difference.
You might see the code 9 occur more at the cooler ambient temperatures.
** As an after thought, sounds like you have a set of gauges. At what pressure does the compressor drop out ( should be around 22.5) and what pressure does it re-engage (should be around 46). This would ensure the cycling switch is basically OK.
Old Sep 20, 2019 | 04:05 PM
Josh Brown's Avatar
Josh Brown
Thanks for the reply. After the 1 minute of code 9, everything works flawlessly. Compressor runs all the time. Stays at 30psi on the low side. Doesn't drop or turn off. It's just as soon as I turn the key on, its throwing a code. Gotta be something electrical, not the low side switch. Jumped it already.
Old Mar 2, 2021 | 10:45 PM
Josh Brown's Avatar
Josh Brown
So as an update for the future person searching. The issue was the stuck blend door. It would throw the code on the HVAC system for 1 minute while trying to move. The system would then just give up and throw the code and allow it to run normally. Never did fix it just dealt with the heat for 1 min.
To HVAC Trouble Code 9???
