Octane
Old Oct 15, 2019 | 09:40 PM
CameronPiggot's Avatar
CameronPiggot
7th Gear
Default Octane
Hey I have an 87’ corvette and I’ve been putting 93 octane in it for the most part and 91 and 89 sometimes. What is the best to put in for this certain engine and year so it runs the best? Thanks
Old Oct 15, 2019 | 10:12 PM
jv9999's Avatar
jv9999
My '87 runs best on 91+. The knock sensor will retard the timing on anything too low.
Old Oct 16, 2019 | 07:48 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
That's just it, the knock sensor will allow the ecu to adjust timing based on knock. It will keep your engine safe regardless of what octane you use. Back when my car was a stock street car I ran 87 in it all the time until race day I would switch to 93.
Old Oct 16, 2019 | 08:11 AM
vader86's Avatar
vader86
My 86 ran all day on 87 octane and never knocked, my 88 got midgrade before I changed the engine. You want the lowest octane that doesnt knock for best performance.
The only way to truly know is hook a scanner up and see if you get knock counts while youre driving. Your compression is low enough that midgrade should be fine, but try not to use 87 octane.
Old Oct 16, 2019 | 09:08 AM
RetroGuy's Avatar
RetroGuy
Unless you live in a state, such as California, where premium gas is currently over $4.20 a gal, or you're financially strapped...always use premium!
Old Oct 16, 2019 | 10:50 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by vader86
My 86 ran all day on 87 octane and never knocked, my 88 got midgrade before I changed the engine. You want the lowest octane that doesnt knock for best performance. The only way to truly know is hook a scanner up and see if you get knock counts while youre driving. Your compression is low enough that midgrade should be fine, but try not to use 87 octane.
^ ^ This ^ ^
My 86 also ran just fine on 87 to the day I sold her. I tried different octane fuels with zero performance or mileage results.
After following this topic for better than a decade, it's easy to say, running hi octane fuel (premium) does nada for low compression engines.
Old Oct 17, 2019 | 05:41 AM
bjankuski's Avatar
bjankuski
My 1986 vette would knock and pull timing even with 93 octane fuel when it was all stock. If I ran 87 octane fuel it could not pull enough timing to prevent it for detonating and you could hear it knocking. With 93 I could not hear it but the scanner showed lots of knock retard. The 9.5 compression, cast iron heads, and high operating temperatures of my car combined together to make 93 octane the best fuel fo me.
To Octane
