Car is having a (wiring) meltdown...
Old Mar 3, 2020 | 05:52 PM
  #121
Saftie's Avatar
Saftie
Difficult to say. The yellow residue points to a fire extinguisher being used.
There was damage to the wiring between engine and firewall, near the distributor. I found that the harness was not clamped down. So it might have touched the engine.
No way to tell though if that was removed before or after.
Someone definitely did something to the engine/airplenum.
The intake manifold sealant was not factory, the tps sensor was way off and the throttle body says Edelbrock. The spark plugs wire ends were mixed up as well. What should have been connected to distributor was on the plugs and vice versa. Relays on driver side were just dangling around and not clamped down where they were supposed to be.
​​​​​​there was something else that was not right but I forgot what it was...
The few times I had the car running I never noticed any gasoline smell not saw any leaks.
Old Mar 8, 2020 | 07:57 AM
  #122
Saftie's Avatar
Saftie
Started comparing my harness to the 88 in more detail and there are too many small differences.
So I started to open up my original and I do think it can be fixed.
The one spot that appeared to be damaged the most is actually not too bad now that the plastic shielding is removed. Photo below.
I reached out to jims performance to see if he wants to take on this job. If not I will do it.
The 88 harness will be my donor for connectors which are no good on mine.
Old Mar 10, 2020 | 06:27 AM
  #123
Saftie's Avatar
Saftie
Shipping my original harness to jim. While he is working on it I am addressing other things on the car.
I have always wondered about one wire/connector that was not going anywhere.
does anybody know what this is, where it goes? It's the green/white wire in the pic.
Old Mar 10, 2020 | 09:11 AM
  #124
Bfenty's Avatar
Bfenty
2017 C4 of Year Finalist
That looks like a knock sensor pigtail-but it should be on the passenger side not the driver side. Look right between the spark plugs for cylinders 6 and 8 (rear passenger side), it should plug into the sensor right there.
Old Mar 10, 2020 | 09:15 AM
  #125
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
coolant temp. its at cyl 1.
Old Mar 10, 2020 | 09:18 AM
  #126
VikingTrad3r
Oil Producer
Old Mar 10, 2020 | 09:23 AM
  #127
Saftie's Avatar
Saftie
Thanks to both of you. I will check tonight.
Old Mar 10, 2020 | 10:36 AM
  #128
Bfenty's Avatar
Bfenty
Oops-yeah Viking is probably right, ignore me. They look similar, but the location makes it obvious.
Old Mar 11, 2020 | 07:04 AM
  #129
Saftie's Avatar
Saftie
that's what it is. The plastic on that connector on the engine is completely broken off that's why I didn't see it before. Have go replace. Thank you for finding it
I think it's the cooling fan switch though from what I researched after your tip.
Old Mar 13, 2020 | 04:00 AM
  #130
Saftie's Avatar
Saftie
Got the switch...
also cleaned a few more things....
Old Mar 13, 2020 | 04:14 AM
  #131
Saftie's Avatar
Saftie
Was looking at all my pics that I took during disassembly and realized there was nothing bolted down to the circled part of the intake manifold. At least I didn't find anything.
what should go there?
Old Mar 13, 2020 | 06:36 PM
  #132
Bfenty's Avatar
Bfenty
My completely stock car has the same empty bolt hole. Not sure what it’s for but I don’t think you’re missing anything.
Old Mar 13, 2020 | 06:42 PM
  #133
Saftie's Avatar
Saftie
Cool, that's what I thought else I'd have taken a pic of it.
removed the dash pad today, came off easy. Will be digging into it a bit more over weekend to get to heater core and check wiring.
Old Mar 13, 2020 | 07:19 PM
  #134
Saftie's Avatar
Saftie
Here a pic...
it's really a 'get to know your car' now.
Never noticed that lever o/ slider top of steering column. No idea yet what it does and need to research. I also never noticed the reading lights in the rear view mirror before. Really cool.
Looks like I have to pull the steering wheel at some point. Done it several times on my Chevy truck, so nothing new but always disliked doing it.
there was also a thing between dash and windshield that looks like an antenna. Not sure what that does and have to trace the cable.
Maybe someone put that in instead of fixing the rear antenna. Also have to see what that little red light is supposed to do that's left of the steering wheel. Don't think that's stock.
Old Mar 14, 2020 | 06:20 AM
  #135
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
My 90 does not have the lever, they did away with it in that year but my 84 that I used to have had it and if I remember correctly it allows you to extend and retract your steering wheel. also since your working on wiring my latest video is about solder guns.
Old Mar 14, 2020 | 02:23 PM
  #136
Saftie's Avatar
Saftie
Heater core is out. And other stuff...
There are cut wires coming from the center console. Have to check what they are supposed to do...
Console out, might as well. Easier to clean and have to check for the cut wires anyway.
Old Mar 14, 2020 | 05:01 PM
  #137
eutu1984's Avatar
eutu1984
To make it a little easier take a screw driver and pop out the button in the middle of the shifter **** then remove the c-clip, pull up on the shifter **** and it will allow you to get your shifter boot off.
To Car is having a (wiring) meltdown...
Old Mar 14, 2020 | 06:00 PM
  #138
Saftie's Avatar
Saftie
Doesn't bother for now.
Spent some time under driver side panel. I don't even know where to start. Trying hard to understand what was done and why... Have to get my manual out and see what's what.
The pic in the middle: there are two relays that were wired in. A lot of pins are being jumped and there is no connector. It's all just Home Depot connectors held in place by tape. There is also an online fuse going into one of them.
I don't think this was done because of the starter button. Maybe the harness was from a different year and they modified it? No idea. Doesn't make sense to me right now.
Old Mar 14, 2020 | 06:37 PM
  #139
Hot Rod Roy's Avatar
Hot Rod Roy
Sir, you have a challenge! A bunch of that wiring is from a previously installed Keyless Remote Entry, or a Remote Start system by Directed Electronics. https://www.directed.com/
Unfortunately, the system was crudely removed, so you'll have fun figuring out how to remove all the extra stuff you no longer need.
That lamp cord wiring might be for speakers
Old Mar 14, 2020 | 06:43 PM
  #140
Saftie's Avatar
Saftie
Cool, that info actually helps.
Thank you!
