Tuning recent LT1 Build - Split BLM's
Attached another LOG of tune #2. Same route as before. This LOG is post VSS repair. Thought I would log as I had done some adjustment to IAC counts AND I calibrated the ASR which tweaked shift points. Probably didn't alter much but just in case.
is it possible someone could corrupt some file on the plug in chips?? I have 4 of those computers from years ago, I swap them around once in a while, I have two chipsets, one from an unknown source, and another much larger chipset from Alvin Anderson.......
the engine is a basic L98, with 1.6 rockers, L98 heads but a highly modified LT1 induction on top, with HEI in back, 52mm tbody...there is no EGR..does have the stock PCV of course..I have swapped all sorts of parts around over the last few years, and nothing seems to fix it.....age 76 here, so it's not driven every day, but quite often as it's my only wheels, except for wife's car.....
SO, with the info above is it possible for one of you to burn me a chipset I can just plug into the computer and hopefully cure this mess?? I"m an old ET and so installed this F Inj back in '95.....
PM ME please, with price and information, I can return old chipsets to you for parts anyway.....
GENE
