Hey folks, I'm new to this forum (first Corvette forum ever actually). I been working on debug and tune of my '92 Black Rose C4. Build outline included below. I'm working with a seasoned tuner and trying to align the BLM's. I've done quite a bit of troubleshooting (new single wire O2 sensors), FP at rail. I've deleted the CATS and I'm running Exotic Muscle OT headers w/ O2's in collectors. I'd be happy to share log if anyone could perhaps provide some troubleshooting guidance. Thanks in advance.
1993 Black Rose Corvette (38k miles). Three years ago I started accumulating parts as part of a build plan. Included Dana 44 (3.45 gearing) , 4L60 build with 3200 stall, LT1 build (LE2 heads and 227/235 .565.579 110 LSA Cam, 1.6 Lunatti RR, LE2 ported intake, 58mm BBK, 30lb injectors, Exotic Muscle LT headers).
There is not much that can be done about the split BLM's, just make sure there are no mechanical issues like vacuum leaks, header leakes, fouled plugs or ??. The 1992 is a batch fire car and the LT1 intake has some fuel distribution issues at light throttle low RPM. The later cars 1994 to 1996 had sequential fueling and they adjusted the pulse width by cylinder at low throttle to tune out this issue. Just make sure the mechanical issues are good and dial in the tune the best you can.
Wow....I'm doing the same thing, although wrestling with the rear and need to buy headers, TC and push rods. Other than that I have everything (even fluids). Had my trans rebuilt (Lloyd recommended a 3200 stall). I also have suspension & brake rebuild parts ready to go. Was waiting to send out the block and BAM the damn wuhan virus hit
Tune it as best you can in Closed Loop. Then run it in open loop and clean up the idle (BLM Cell 16, 17) Then leave it in Open Loop permanently...trust me .
Folks... any recommendations of Tuners that can help me get from "stable" to "optimized performance" on my '93 LT-1 build. While the BLM's seem to be a stabilizing, I need to get some help with performance tuning. Any help or a point in the right direction would be greatly appreciated. Thanks
You might want to look at the BBK 58mm TB as a problem. Do a Google search for Split BLM and BBK 58mm Throttle Body. It will bring up the camaroz28 forum, I found the thread rather interesting. I made mods to my BBK 52 mm throttle body when I did my cam change (smaller cam then yours).
Also check out this: https://ls1tech.com/forums/lt1-lt4-m...d-pp-tb-4.html
Good luck!
Reason: link didn't work
You may need to convert to heated O2s if O2 voltages are lazy. What kind of numbers do you have?
I've attached, in both text and excel format, my latest LOG files. Note the BLM and what I am fighting. Seems the right side is consistently leaner than left since I've been making adjustments. I'm NOT a mechanic but I did make one observation which may or may not be meaningful. Specifically, I removed the poly valve covers to insure the oil drip tabs were completed removed to clear the larger RR's. In doing so, I noticed a bit of exhaust smell inside the left Valve cover. The right has the EGR tie in so maybe that's normal?? Anyhow, ANY help or guidance that can be provided on the tune would be greatly appreciated. The car runs smoothly (idles OK, accelerated OK etc) but doesn't have the power I'm expecting. I've been reading and researching and noted that there are quite a number of experts out there... hoping to engage with one!!
Thanks again.
One addition, I was just reviewing a LOG from earlier in the week in which the BLM's looked more closely coupled. I'm working remotely with a Tuner (unnamed) and the only changes were VE adjustments and physical TB idle position. See the dates on the files.
There seems something wrong with the first capture. You are only using BLM Cells 16, and 18, during the entire log. That's not right it should be using more Cells than that for fuel correction. BLM Cell 16 is only for Idle. And I believe Cell 18 is a special function Cell usually triggered during CCP ( Charcoal Canister Purge). From what I can tell you are not going into proper fuel correction. This happened to me whenever I lost VSS signal.( Is your Speedo working on your instrument cluster? )
Can you post whatever files you are using for datalogging. BIN File, XDF File, ADX File.
The Speed-o is working fine. That log was a fairly benign ride compared to the latter. I've attached the other requested files below:
The Definition file is the following:
- $DA2 ECM Definition File fro Data C.A.T.S
- The "BPONTUTI8 BDBK YB auto.BIN is the latest tuner (ECM) program
I had been using Tuner PRO RT... The files I was using for that (previous to the logs posted) were:
- $DA3-16159278-V2_ALDLDroid_Modified.adx (you have to remove the .txt from the file name (I couldn't upload .adx without adding the .txt)
- $DA3-16159278-V2.1 (Again, remove the .txt)
Any help or insight you can provide would be greatly appreciated. I switched from TunerPro RT to Tuner C.A.T.S and Data C.A.T.S. because I was having occasional "synch" errors with TunerPro... the same problem occurs with Data CATS however so I just live with it.
I'm not sure what your seeing. I've re-attached the files with the BLM cell included in the data. Also, the previous log files were truncated and didn't include the full data set. Again, I'll take any help with tuning I can get.
Do you have hardware to burn your own BIN ( prom ) ?
If I send you a modified BIN can you burn it and place it in your ECM
Also, do you have a Wideband hooked up to your vette
I do have a Moates burner and a G2 Memcal adapter. I use Flash and Burn to burn chips. I am using Tuner C.A.T. to look at the tune files and gain an understanding of the process. I use Data C.A.T.S.
Ok that's great that you can burn your own prom. I already see issues with your existing BIN that I will improve on. Once I make some changes I will send it to you via Private Message.
I would highly recommend trying to get a Wideband installed. It will really help the situation.
I can install wide bands no problem. I just installed new O2’s two weeks ago and when I inquired with the the guy that had been helping me with the mail order tune i was told the ECM can’t process the wide-band data. If that’s not the case I will order wide-bands and install.
And... thanks for your help!! I really appreciate it.
The wideband will be useful for visual to see what is happening. (only 1 wideband needed on whatever side you choose) Especially great when dialing in WOT
Also, what fuel are you running? What is the Ethanol content % if any?
I will order a wide-band O2. I use Shell 93 Octane. Not sure of ethanol content but will check when I am there next.
