but wait....i thought you just need to port the cfi, use a 85 fuel pump with adjustable fuel pressure regulator in place of the factory one, set to 14psi, and bump timing to like 10deg or something like that and we are at tpi or better levels. ? i mean anyone who gets a used crossfire is more than likely pulling apart to clean it up, and you can probably find a local person or yourself to port the intake following a few well documented online pages...
im not being facetious im actually asking...i have an 84 for my daughter here and that was my plan....is there an easier bolt on plan that “just works”?
I dont want hassle i just want the factory stuff to work.
Something like the SY-1 or an Offy is for chasing bigger power gains....like a 383 CFI w/head, roller cam, etc. You can't port a stock CFI intake enough for a motor like that. But for a stock motor, port the runners, bump FP, advance timing and do exhaust.
So, I've been doing some serious soul searching... The difference between the theoretical and actual power output is bothering me... So I am curious. What can we all speculate the issue is or more so, what would you all like to see tested/tried on the dyno. I kind of want to pull the mufflers and see if I pick up anything. 3 inch necked down to 2.25 inches out the back may or may not pick up a few horsepower. (You know, because I obviously need the backpressure to make supah torqs. ) I am thinking that would possibly show a few numbers gain though.
Outside of that, in the current configuration, I don't see much to be improved other than with the tune itself and even that may not be much.
Swirl plates vs. not,
Radiused lid bores or not
Tower spacers vs. none
Parallel plumbing vs. stock/series plumbing
^All things that folks make claims about, but I've never seen diddly to support one way or the other. I don't think the muff's will do squat, but I love ANY dyno comparo's so I'm all for that, too!
I can tell you I'm parallel plumbed currently... I tried leaving it in series with just block off plates and had issues. Which after I had the break up issue with the hard lines I think you recall, came to realize that it was probably due to no dampener/accumulator. In anything close to stock or running near stock fuel pressures I can't see any reason to parallel plumb. In my situation I can but that's because the stock diaphragms I doubt would hold up well to 28 psi of pressure long term. If I could find the marine diaphragms which are a thicker rubber I would gladly try it but that's one I don't think I'm brave enough to test.
Swirl plates I planned on testing with the Ported intake. It was going to be as follows:
Ported with stock lid and TBs
Ported with deleted swirl plates
Ported w/o swirl plates and 2 inch TBs
I can add in the pod spacer but again, it's one of the things I only see necessary when altering parts... with the 2inch TB without the doubled pod gasket I was seeing fuel hit the blades and puddle giving me a weird idle. The second pod gasket spaced it up enough to put the cone back to stock like... but I'll gladly try it out on the stock TBs.
The radiused lid I'll have to look into more.
flow bench testing showed modified swirl plates flowed the best vs no swirl plates vs stock swirl plates. also cutting off to much of the sides walls of swirl plates resulted in less flow.
there's something about the depth of side walls of the swirl plates that increases the flow. Stock pitch of swirl plates blades worked the best for me. Tried more pitch and less pitch, stock pitch worked the best for me. wasn't much though.
also stock orientation of swirl plates works good. I turned them 360 degrees to see if there was any changes and flow does change a little.
my tests didn't show any gain from radiused lid
Saw something interesting today watching Engine masters. Not that I think it is particularly relevant to the data at hand but, they were talking about and testing injector placement and had a new spacer under the throttle body called a shear plate for lack of a better term it quite literally looks like our swirl plate (sticks a round cylinder into the plenum) minus the diffuser portion. The alleged purpose is to diffuse the reflective wave. Interesting but for our application it doesn't seem like it would be able to cause enough havoc at the throttle body to be a problem.
That, and the CFI plenum is pretty big. IMO, that size would lessen the affects of reflective waves on the TB. No science to back that up. Just a hunch.
Plus the sudden expansion as it leaves the runner. This was on a tunnel ram type setup iirc. So very much runner line of sight to the baseplate. Pretty much every runner in a CFI would have to be shortened a lot to have that benefit or the pulse would have to make a 180 off the side wall.
I saw that also. they said it was more for a carburetor metering. reflective wave messes with the metering.
precisely. I've actually seen slow motion videos of carbs under WOT conditions and you can actually see back splash through the venturi and out the top of the carb. Pretty cool stuff. I could see back splash being a problem on TBI but not on anything close to what came in the car stock... the reflection just doesn't have enough power behind it and again, large plenum. It is kind of interesting the later TBI intakes had none of this that is present on the CFI despite operating in a similar manner. I do think they had some sort of down leg cast in though. I've never held a TBI intake in hand.
