Harness Bar?
Old Jul 14, 2020 | 02:32 AM
Daniel Juliano's Avatar
Daniel Juliano
Default Harness Bar?
Does anyone know where I can find a harness bar for my 94'
any leads would be appreciated
Old Jul 14, 2020 | 07:06 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
this is the one I use, in fact, that is my car. I gave them permission to use the picture I shared with them
my wife made the padded cover. it is made out of upholstery grade vinyl. JoAnn fabrics has the exact match for torch red. they also have black, I didn't look for other colors
I put mine in to tie the hoop together.
just for the record, I did have to have one of the holes welded up and redrilled, their jig must have slipped. it cost less to fix it than to ship it back, I am very pleased and consider it worth the investment
https://www.ebay.com/itm/C4-Corvette...MAAOSwNX1b83IG
Old Jul 14, 2020 | 02:30 PM
ChumpVette's Avatar
ChumpVette
Are you actually using it to mount a 5 point harness, or are you just going for looks?
Old Jul 14, 2020 | 03:55 PM
drcook's Avatar
drcook
If you are referring to me, I use it to tie the hoop together. It along with the camber brace, tightened the car up a lot. It acts like the bulkhead behind the back seat of a car. The car is vastly improved since we got it. The pin top shock mounts from Banski helped a lot also as you don't have to wait for the rubber to compress before the shocks start working.
I have it bolted in tight and actually used steel dust JB Weld to make the fit to the bolts that go to the upper seatbelt mounts perfect. I waxed the bolts and packed that JB Weld around them.
The hole is as tight as if I had reamed it.
Old Jul 14, 2020 | 05:30 PM
ChumpVette's Avatar
ChumpVette
Asking the OP what his intended use is.
Yours is not a harness bar. It is a “Chassis Bar”. Any harness attached to it, is improperly installed.
Old Jul 14, 2020 | 06:26 PM
drcook's Avatar
drcook
How do you figure that ? Most harness bars just go straight across. Exotic Muscle's anchors to the frame via the 4 bolts that held the targa top holder and the 2 seat belt bolts. They are the ones really doing the anchoring. Their picture out on eBay shows harnesses attached.
You should be telling them. I just use it for chassis reinforcement.
Here is one from Ecklers
https://www.ecklerscorvette.com/corv...1991-1996.html
same as Ecklers, just less expensive
https://www.vividracing.com/brey-kra...-p-155796.html
Old Jul 14, 2020 | 07:27 PM
ChumpVette's Avatar
ChumpVette
Harnesses for SAFETY have specific standards for mounting. It needs to be on a 0 to -20 degree mount. Your Exotic Muscle Chassis Bar drops it down to roughly a -80 mount. The Brey-Krause Bar is properly configured.
This is a typical rule
"B. Cars must incorporate a main hoop horizontal brace at the approximate level of the driver’s shoulders but not lower than the shoulder belt mounting point as described. If a double-diagonal “X” brace is used in the plane of the main hoop, a half-width horizontal brace may be used behind the driver’s seat to mount the seat back and shoulder harness."
Old Jul 14, 2020 | 07:32 PM
Purple92's Avatar
Purple92
Not sure if they still make it - but I think mine was made by Arizona Speed and Marine. It's not on their website - but you could give them a call.
ChumpVette's Avatar
ChumpVette
Just to add, here are some belt instructions.
Old Jul 14, 2020 | 07:41 PM
drcook's Avatar
drcook
As I said, tell them. All I use it for is reinforcement.
However, it is good to clarify for others that are going to actually use it for a harness bar. Of that I agree.
Old Jul 15, 2020 | 11:09 AM
Aardwolf's Avatar
Aardwolf
The two bolts on either side in the back are just into fiber glass.
To Harness Bar?
