Vacuum Check Valve
Old Oct 15, 2020 | 10:29 PM
Furias15x's Avatar
Furias15x
Default Vacuum Check Valve
Hello,
1996 LT4
There is the 2 hose vacuum check valve on the passenger side of the intake manifold. Off of the check valve are two small vacuum lines that run into the large wife bundle. If I pull the connector from the manifold should it hole vacuum with a mityvac?
Or do I need to test each line separate from the valve?
Where do each of those small lines go once they enter into the wire bundle?
Thank you
Old Oct 15, 2020 | 11:09 PM
jv9999's Avatar
jv9999
It should hold pressure, but it might take some pumping. I believe one goes to the HVAC system and the other goes to the cruise control and vacuum reservoir.
Old Oct 16, 2020 | 11:16 AM
InfomanSS's Avatar
InfomanSS
https://www.corvetteforum.com/forums...t-working.html
To Vacuum Check Valve
