diff draining
Old Dec 7, 2020 | 05:31 PM
billyride's Avatar
billyride
Default diff draining
Where do I get a socket(??) to remove the differential fill plug on a 1995?
Old Dec 7, 2020 | 05:45 PM
Nomake Wan's Avatar
Nomake Wan
Isn't it just a square? As in, the same shape as what sockets connect to on your driver? Pretty sure you just use your socket wrench minus the socket to get that thing off.
Old Dec 7, 2020 | 05:54 PM
billyride's Avatar
billyride
Not on a 95 C4.
Old Dec 7, 2020 | 06:30 PM
Nomake Wan's Avatar
Nomake Wan
Originally Posted by billyride
Not on a 95 C4.
Whoops, you're right, it was only a square on non-Corvette models using that diff. The Corvette used a 17mm hex socket.
Old Dec 8, 2020 | 04:05 PM
InfomanSS's Avatar
InfomanSS
A set like this would be handy... https://www.summitracing.com/parts/oes-25374
Old Dec 8, 2020 | 09:46 PM
jv9999's Avatar
jv9999
I just use vicegrips. There's not a lot of room up there for a ratchet. At least on the D44.
Old Dec 9, 2020 | 11:27 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Get a nut w/a 17mm head. If it's not thick enough, then get a bolt w/a 17mm head, a pair of the corresponding nuts, and double nut the bolt. Use the bolt head as a driver and the outer nut driven by your socket or wrench.
To diff draining
