Trying to minimize wheelies
With my '89 drag Vette, I have had good luck without wheelstands using a loaded IC of 41" and 8" (1.27-sec 60-foot time).
Your car looks awesome!
-Larry
-Larry
..... Unfortunately I live alone and do not have pics of the rear suspension with me in the drivers seat ... I will be getting back under there and will snap a pic of the suspension loaded sometime later this week .....
If you can lower rear ride height safely (with respect to tire clearance), I'd try that along with maybe raising the top link one hole or two (looks like the lower links are already as low as they go?). Another thing that could help would be to lengthen the wheelbase by both upper and lower links the same amount. Even 1/2" would help if you can do that safely.
Lower forward: (horizontal?, 16)
Upper forward: (horizontal?, 24.25)
Lower aft: (horizontal?, 15)
Upper aft: (horizontal?, 25.3878)
When lowered to the floor and settled, how much will these vertical measurements decrease?
To answer your questions, my car is quite light - 1050 front and 1150 rear. It runs 9.0s at 148 mph (NA) with 454 BBC LS7 with a solid flat tappet cam.
Comparing the different pictures of your car, including the one in your signature, we can see that the gap is huge between the back tire and the lip of the quarter panel in the latest one. Obviously, the car is doing different things now on the launch but not what you desire. Can you post a picture of the four link bars with the car on the ground and possibly with you sitting in the drivers seat?
Mike.
Lower forward: (17.39, 9)
Upper forward: (12.75, 17.25)
Lower aft: (1, 8)
Upper aft: (1, 18.39)
This makes an instant center at 66.7" forward and 12.0" above the ground.
Send me the new hole locations and I'll calculate the current IC.
Lower aft: (1, 8)
Back to the original question... To control wheelies with a far forward IC, more front shock extension damping and more weight will help, but moving the IC back to under the CG (-46") should be even better in my opinion - but only testing will tell. Are you heading to Bradenton this weekend? Keep us in the know!
Snow fun in MO
-Larry
Snow fun in MO
-Larry
