Trying to minimize wheelies
..... So I adjusted the 4 Link bars and installed an improved front suspension limiter and made a hit at Bradenton "Street Heat" last Saturday to get this .....
..... Made some more adjustments to the link bars and moved the Instant Center back another 10" ... that's 26" total since Gainesville ... will go to the TnT at Bradenton on Thursday and we have points races on Saturday and Sunday . Hopefully I will get the front down without losing rear bite ... all adjustments made are keeping the I/C above the anti-squat line to plant the radials and not lose traction .....
Just kidding, thats an awesome problem to have (if your not the one trying to dial it in!)
Lived in st Pete for years. Never got a chance to make it to that track. Looks awesome!
Lots of other things can help. Rear extension/seperation can be used to "push the front down " but that's a game of timing the rear seperation vs the front extension. It is a razor's edge and it can cut you because if you wheelstand with the rear suspension separated.... you just made it where the car can climb even higher before hitting the bumper.
Weight. I know all the wives tales about -100lbs = a tenth.... obviously we want the car as light as possible but none of that applies when the car won't work. Sometimes adding 20-25lbs strategically placed on the front end can make a huge difference.... as far forward and as low as you can get it. Weight distribution is a real concern with radial tires. FYI, my car is 54% front and it's not enough. We resorted to a bunch of tricks on my car as it was built and subsequent modifications to get that much. I still carry ballast in the front of my car and have raced as much as 50lbs overweight but it makes the car faster.
Its never ending keeping on top of the suspension as you get faster and I'm still on the struggle bus at times with mine. Good luck with it.
Will
Will
That's a 5/8" aluminum block attached to the bottom spring stop plate to limit front spring travel ... I have some 3/4" stock that I want to try .....
How does going with different front shocks change how high it will pull the front end? I understand the shock will unload differently but at the same time if there is enough power to pick up the front up like you are it will just pull the whole thing off the ground no matter what that shock is doing??? How does the front shock effect the rear end? Or is this just so you don't smash the oil pan off with every pass.
If you go to wheelie bars then you can adjust the overall rotation during launch and force the tires to take the brunt of the power moving the car forward rather than rotating the car. But then you have to have some serious tires to take it. But it looks like do have them.
If you go to weight in the front end you are using you're using cantilever effect to keep it down. This is a good option for sure. But it would be a tuning game for sure at every track per the surface and traction to find the least amount needed for the proper launch. But it might not be that sensitive that far away from the rear end.
Wheel speed? Does that come into play here? Get the wheel speed up at launch and the front end will stay down?
Sorry for so many questions I just find this stuff very cool!!
In general, shocks modify the rates of weight transfer. However, when you get to the point where any pair of wheels are coming off the ground then I don't think the shocks for those wheels can really do anything anymore: you've achieved 100% weight transfer at that point. In the case of wheelies, the rear shock valving seems like it would be important, but the front valving will be more important for controlling things when the wheels come back down. It's entirely possible I'm missing something here, though.
At the rear, the things that could mitigate wheelstands will also hurt traction, so it's a balancing act. For example, lower ride height and CG will help control wheelies but will reduce rearward weight transfer (which you want for traction). If you can soften rear compression damping and increase rebound rate that could help get that balance by keeping the rear from rising as much and as quickly, thereby lowering the CG of the whole car. Lowering rear ride height would help for the same reasons, but your tires and fenders probably put a hard limit on that.
As for car weight, moving weight forward/lower is better than adding weight forward/low. Obviously there are limits to this, and adding weight is faster than having to pedal the car, I'm sure. It's definitely safer!
Talking about that balance thing again, you might try lowering the IC to see if you can retain enough traction to just barely unload the front tires completely while not sending them skyward. Or at the very least, again cranking up rebound rates on the rear shocks to try to slow down that gain in ride height. Wheelie bars are another means of trading off rear-tire traction for control.
Think of a weight lifter deadlifting a 200lb barbell. We can put springs or dampers between the barbell and the floor, but if the weight lifter can apply more upward force than 200lb, that barbell is coming off the floor no matter what.
