Need immediate HELP if possible...
Old Jan 25, 2003 | 07:40 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Need immediate HELP if possible...
I am trying to meet a bunch of Forum folks at the NCRS show this morning...here's the problem...started my car this morning and after running for a couple of minutes I heard a strange buzzing coming from under the hood...then I got an "Service ASR" light..at the same time the "Security" light just to the left of the tach flashes 3 times and goes off for a minute then repeats...shut the car off and restarted..no lights...went a couple of miles and same lights....got the car back home and now it won't even start !!!..is there anything I can do to still make the show ?...thanks.. :cry
p.s. I borrowed a car to run down to the show..all thoughts still appreciated..
[Modified by golfboy1, 7:59 AM 1/25/2003]
Old Jan 25, 2003 | 11:08 AM
don hall's Avatar
don hall
Default Re: Need immediate HELP if possible... (golfboy1)
It would really help if you could provide any trouble codes that might exist............. http://www.c4vettes.com/ecm.htm
Old Jan 26, 2003 | 09:01 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
It sounds like you have two isolated problems: VATS is kicking in and the ABS system has sensed a problem. Pull some codes and let us know what it shows. :seeya
Old Jan 27, 2003 | 10:50 AM
WOEII's Avatar
WOEII
From: [QUOTE=onedef92]Remember when that spookable closed the door on that mofo and trapped him inside tha
St. Jude Donor '06 thru '11
Any updates? :seeya
Old Jan 30, 2003 | 09:11 AM
Wolf1171's Avatar
Wolf1171
From: Winter Jam I and II Veteran, Bahama Jam 2005 Veteran
CI 4, 5, 7, 9 & 10 Veteran
St. Jude Donor '03-'05-'06-'08
Default Re: Need immediate HELP if possible... (WOEII)
Any updates? :seeya
:lurk:
Old Jan 30, 2003 | 09:32 AM
GusBustamanteJr's Avatar
GusBustamanteJr
I bet it will start if you just let it sit for 30 minutes. If not pull the ECM lead to the battery to speed things up.
Old Jan 30, 2003 | 10:15 AM
Toms86vette's Avatar
Toms86vette
I don't know if this will help you but my 94 had similar problems. The ASR ON, ASR OFF, Service ASR + ABS & Service ABS lites started flashing along with the security lite flashing 3 times. They would stop flashing and the car would run normal. Finally they started flashing and would not stop. I had the car scanned and it turned out to be the ABS pump behind the drivers seat. When the pump was disconnected the car run fine. Finally I left the pump disconnected until I can afford to replace the pump. I have no proble driving with the ABS pump disconnected, but I havn't had any bad conditions as of yet.
I hope you cure your problem and roll on. Tom :seeya :party:
To Need immediate HELP if possible...
