Is this normal
Old Feb 21, 2024 | 06:32 PM
BET VETTE's Avatar
BET VETTE
Default Is this normal
I’ve seen a c4 with this perfectly round hole under it between the oil pan and the tranny pan
Old Feb 21, 2024 | 06:41 PM
bjankuski's Avatar
bjankuski
Yes
Old Feb 21, 2024 | 06:42 PM
WVZR-1's Avatar
WVZR-1
Normal on an 4A auto that hole is in the converter cover, if you had a leaking front pump seal you might expect drips. That's a very clean cover.
ex-x-fire's Avatar
ex-x-fire
Yes, could you imagine if there wasn't a hole and a quart of atf filled that then got sprayed all over the exhaust when you started it up?
Old Feb 21, 2024 | 07:14 PM
s carter's Avatar
s carter
As mentioned totally normal and planned, it's to let any lost oil out. Also some people are not smart enough to avoid hitting deep puddles that would make a great well to hold water if it doesn't have a drain
Old Feb 21, 2024 | 07:24 PM
BET VETTE's Avatar
BET VETTE
I thank you all
To Is this normal
