Supercharged l98 Questions
Mine currently has a PLX AFR gauge and sometimes when the car is off it will fluctuate all over the place before settling at "LEAN'. Please correct me if I am wrong but this is not supposed to happen as this could show me some incorrect values while running.
In addition I got my BTM in and I am getting it all hooked up this week. I got the Kbob set up and wired through the firewall so but I did want to see if there are any ways to confirm the functionality of the BTM once installed, would I just hookup a timing light and confirm timing is being pulled as throttle increases or is there another way to confirm it is working?
I also got a borescope and took a look through the spark plug hole and I am just about positive that the previous owner had reused the stock rotating assembly when the motor was rebuilt.
Until I can build a forged motor which isn't in the cards for the near future (I'm throwing some money into my 4runner next) how much timing should I pull when I do step on it. As the MSD BTM allows for up to 3 degrees per lb of boost where should I set it?
The intercooled kit is set at 8PSI and I am pretty much only going to have 93 Octane in the car.
I haven't tested it but I was told by the the facility that sold me my Procharger kit to set the BTM at 1 degree. I was going to use 1.5 as a base and drop it from there to get the best balance.
Partial Combined Spark Advance Table (from APYP) :
RPM LV8(208) + PE = Total
4800 35.16 + 1.05 = 36.21
4400 30.94 + 3.** = 33.94
4000 27.07 + 5.** = 32.07
3600 23.91 + 7.** = 30.91
3200 22.85 + 9.14 = 31.99
2800 22.85 + 7.5* = 30.4
2400 24.96 + 6.** = 30.93
2200 27.07 + 4.4* = 31.46
2000 26.02 + 2.81 = 28.83
1800 23.91 + 2.81 = 26.72
1600 23.91 + 2.81 = 26.72
1400 21.09 + 2.81 = 23.90
1200 17.93 + 2.81 = 20.74
1000 14.06 + 2.1* = 16.16
800 9.84 + 1.4* = 11.24
600 9.84 + 0.7* = 10.54
400 9.84 + 0 = 9.84
*, **: approximate interpolated values
You don't really want/need to exceed ~26 degrees advance under boost in general, but this is somewhat dependent upon the actual load and charge air temperature (which are unknown without better sensorics). Subtracting 1 degree per psi would be borderline. 1.5 degree per psi seems to be a reasonably safe suggestion.
Source tables for reference:
TABLE: Spark Advance Table
RPM LV8
32 48 64 80 96 112 128 144 160 176 192 208
4800 39.02 43.95 47.11 45.00 40.08 39.02 37.97 35.16 35.16 35.16 35.16 35.16
4400 39.02 43.95 47.11 45.00 40.08 39.02 37.97 33.05 33.05 33.05 33.05 30.94
4000 39.02 43.95 47.11 45.00 40.08 39.02 37.97 30.94 27.07 27.07 27.07 27.07
3600 39.02 43.95 47.11 45.00 40.08 39.02 37.97 30.94 26.02 23.91 23.91 23.91
3200 39.02 43.95 47.11 46.06 41.84 41.13 37.97 30.94 26.02 22.85 22.85 22.85
2800 39.02 43.95 47.81 47.11 47.11 43.95 43.95 35.86 29.88 27.07 24.96 22.85
2400 39.02 43.95 47.81 47.11 47.11 46.06 43.95 39.02 34.10 28.83 27.07 24.96
2200 39.02 43.95 47.81 47.11 47.11 46.06 43.95 41.84 35.16 28.83 28.13 27.07
2000 39.02 43.95 46.41 47.11 46.06 45.00 43.95 41.13 35.16 28.83 28.13 26.02
1800 36.56 38.67 40.08 46.06 46.06 43.95 41.13 41.13 35.86 27.07 24.96 23.91
1600 35.86 39.02 41.84 43.95 41.84 41.13 37.97 34.10 29.88 27.07 24.96 23.91
1400 29.88 39.02 41.13 41.13 39.02 39.02 37.97 35.16 31.99 24.96 22.85 21.09
1200 26.37 29.53 32.34 40.08 40.08 37.97 35.86 31.99 26.02 21.09 21.09 17.93
1000 20.04 22.50 29.88 36.91 35.86 34.10 34.10 28.13 18.98 16.52 14.06 14.06
800 20.04 20.04 24.96 29.88 29.88 28.13 27.07 21.80 16.17 9.84 9.84 9.84
600 20.04 20.04 20.04 20.04 20.04 20.04 20.04 15.12 9.84 9.84 9.84 9.84
400 20.04 20.04 20.04 20.04 20.04 20.04 20.04 15.12 9.84 9.84 9.84 9.84
TABLE: Power Enrichment Mode Spark Advance
RPM Degrees
4800 1.05
3200 9.14
2000 2.81
1200 2.81
400 0.00
I installed my BTM and it made a world of difference, I haven't given it more than half throttle yet as I am still tinkering with the FMU but I have the car idling at at around 14:7 AFR and under harder acceleration it's around 10:3-11:1 and I have the boost retard set at 2 degrees per PSI and even at just half throttle this is the most fun I have had in a C4 yet, especially compared to my previous cammed 1992 6 speed.
I will upload some videos soon but thank you all for help, everything is appreciated.
tps % (load axis)/tps voltage example: https://datazap.me/u/tequilaboy/aldl...olo=2&mark=117
Since a supercharged car's manifold pressure can approach 0 psi (atmospheric pressure) around half throttle (similar to a naturally aspirated car at WOT), Power Enrichment fueling should be active even earlier (around 30-40% throttle). The fmu won't help you here. The fuel trims may help a bit, but will then likely be skewed high during PE.
In regards to boost in correlation to throttle around when does boost start to get built on these centrifugal superchargers? I do know it depends on pulley size and superchargers do build boost under load but around RPMS and throttle would boost come on?
In regards to the MSD BTM under harder acceleration the Tach is off by far, when driving normally the tach reads properly but when under hard acceleration it drops to about 15-1800 rpms when it is for sure north of 4000 rpms, has anyone had issues with any of the MSD systems and the tach output or is there an adapter I need to make it function properly under hard acceleration
It is also a Z51 package so it does have the fan in front of the radiator as well.
I discovered that the serpentine belt was badly torn and very worn out so I replaced it and it hasn’t gone over 220 so I suspect that the water pump wasn’t getting moved sufficiently. I also picked up a 160 thermostat that’s going in soon.
