frustrated
In the picture I posted above, you will see the HKS wastegate to the left of the turbine housing. It is angled off of the header collector to allow smooth flow into the wastegate - this is an external wastegate arrangement. Alot of OEM's and lower power level systems utilize an internal wastegate which utilizes a similar design but is attached to the turbo itself. It utilizes a hole on the turbine housing to bypass exhaust energy and control boost. It't benefit is it is more compact and works well in space limited setups, but it is limited in relative terms to it's ab ility to bypass enough exhaust energy as power levels increase. The result is boost creep, and if boost is allowed to increase beyond what it is mechnically capable of or tuned for, damage will result form an overboost condition.
You need this short cut to keep your impreller from over reving, or producing too much boost/controlling it.
When the wastegate opens, some exhuast goes around, and some continues on into the turbo maintaing the boost setting you set.
the internal waste gates are a simple round flap in the turbo. this also need an external actuator to open the flap.
An external waste gate is pretty big.
You can see it on Montys car, it is between the driver side turbo intake tube(Blue) and the driver side head/valve cover. this is a valve with and in and out port. you would route the exhuast into the waste gate from the header collector, and connect back into the turbo down pipe.
[Modified by bill mcdonald, 7:05 PM 2/11/2003]
If it is, does anyone know how the HKS/Greddy/APEX i boost controllers are?.. They like and sound liek they are really nice...... The APEX i its the nicest i think.. but they are all about $500-600.....
What would I need with an internal wategate to controll it from inside the car?
Thanks in advance, and sorry about all the random questions.... Im kinda excitied.. I ran the idea past ym dad with a whole presentation, lol, he pretty much said its a go.. just have to worry about the headers, heat "Thats a lot of heat" and aluminum welding..... I think its really gonna happen and not just talk :yesnod: :yesnod:
ALso with the external Wastegate, MOnty you said that the wastegate only opens when it reaches a set point of PSI depending on the spring rating, so Where does the conrtoller nobe from the inside of the Car come from or how does that work? I get how a Wastegate works and all, but I dont understand that if it depends on Spring rate, then how does the boost controller change the max boost? Please help me out :confused: ;)
OR later on if I build up my engine and I'm running 800-900 FLy HP then I could go say #20 spring and then get a boost controller so when someone else drives my car they wont feel the full Max POwer of it, Only as much I would allow, IS this some how the way O rdo I got it wrong? NO flames or repeating others, over and over again okay? :seeya :chevy
The pressure from the intake manifold is what tells the wastegate to open. There is no way to increase that pressure, only a way to bleed some of it off to make it less. Hence why it will open at a higher rating than the spring and not a lower one. I hope this helps :cheers:
I'm currently still using a manual"dial a boost" boost controller, but I have an Innovative Turbo MSBC-1 electronic boost controller that I haven't gotten around to installing yet. I like the MSBC (Multi Stage Boost Controller) because it allows you to program up to 6 stages of boost, with a 0-60 psi range in 1 psi increments. It also allows you to custom tailor those 6 stages with up to 9 different boost ramps allowing you to control how fast boost builds in each of theose stages. It also includes a Launch stage for drag racing. Additonal features include shift or gear input allowing you to tailor the boost ramp and curve for different gears or for other conditions via the inputs. It includes a readout for actual, targeted boost, and boost ramp (increase rate). It uttilizes two solenoids - one to increase, and one to decrease boost - rather than one as with most EBC's. Most importantly, it incorporates an internal pressure sensor which will guarantee precise boost control despite changes in atmoshperic conditions, altitude, load, or mechanical variations. MAnual boost controllers cannot do this and are highly susceptibel to changes in baromteric pressure, temperature, humidity, altitude, etc. This will result in inconsistent boost control as atmospheric conditions vary. Alot of EBC do not have this feature.
Unfortunately, the current FAST system architecture does not incorporate the ability to integrate boost control, but the new FAST system will. It will feature user programmable inputs/outputs which will allow you top control boost, similar to the high-end Motec setups.
The new FAST system is supposedly in Beta and due out within the year and is promised to be more like the Motec.
Welding aluminum is more challenging, and requires gretaer skill than welding steel or stainless. I only TIG weld, and have never MIG welded, so I dont know all the particulars for that welding process. TIG is the preffered process for welding aluminum, and you will need to use a pure tungsten electrode, AC current with Squarewave starts for best results. The key to welding aluminum is cleanliness. The material must be clean, deoxidized and uncontaminated. New material is preferred over used, as it is mcuh easier to get a good, clean weld.
You can get aluminum from Burn's Stainless, Specialty Products Desings, aviation/kit plane supply companies, and most metal warehouses/distributors. Since aluminum will work fatigue, it's best to use something like 16 guage material, .065" thickness, for a street applicaiton where durability/reliability is highly desired. for a racing application, thinner material is used for weight savings, but it isn't exposed to as many work cycles as a street car would be.
Back to the wastegate questions, here's a schematic for how to plumb the typical twin turbo wastegate arrangement. A single turbo would be the same, only without the second wategate and plumbing. This should help illustrate wwhat I was trying to descibe in my previous post. An electonic boost controlled ssytem operates the same wy, except the electic solenoids take the place of the manual valve.
So that can control the Engine, Transmission and does it control the Guages as well? Like if you change your rear ratio and Transmission you plug in the FAST system and it will help correct them, from reading wrong numbers?
Now I just got to worry about my weak drivetrain :rolleyes:
Anyways, so Now I think I'm going to go with an electronic Boost controll, Looks pretty cool to. But I dont want to rip out my CD player or A/C Controls. I think I could mount it where the cup holders are and just take them out and install the Boost Control. Also I could put a lock on it, so when I let someone else drive it it will be only limmited to what I set it to before I get out and let someone else drive it around( Highly unlikely anyway) :yesnod: What other places could one place thy Boost controller in thy cockpit? :lol: No for real's, any other places? ;) :chevy
I am not familiar with what diesel or junkyard intercoolers would work, but I would suggest posing the questing to the JYTurbo group or the forced induction/power adder sections of the F-body forums. There are many guys over their doing home-made system using used parts. They can tell you what cars make good donors. More than likely, you will still need to modify the intercooler to fit your specific application. I've seen alot of guys used a Powerstroke intercooler and cut the end tanks off, and reweld new custom tanks on.
Here's the link to F.A.S.T.. If you have any specific questions regarding F.A.S.T. or other aftermarket EFI sytems, check out the EFI forums on the Turbobuick.com and Chevytalk.com sites. The moderators of the forums are employees of F.A.S.T. and Holley EFI.
Unfortunately at this time, F.A.S.T. or Accel DFI do not control the transmission (other than convertor lockup for the DFI). You'll need another stand alone transmission controller like the F.A.S.T./TCI T-com or equivalent if you have a 4L60E or 4L80E. However, your factory computer can still control the tranny even if you add the aftermarket ECU to control the engine.
Neither system interfaces with your gauges.
SO if I go this WasteGate stuff right, you could put the external wastegate before the Turbo and then I would have to make an extra pipe from the watsegate so when it leaks out the extra gasses they can escape, and go to the down pipe or something like that? ;)
Then as you mentioned you need to handle the wastegate discharge. I routed my wastegate discharge back into the downpipe since mine is a street car, but for racing applications or for situations where maximum performance is prioritized over system complexity, weight, and noise, you can simply exhaust the wastegate into the atmosphere. An open wastegate under load or at WOT makes alot of noise though. If you didn't want to route the wastegate discharge back into the downpipe/exhaust system, you could built a seperate exhaust ssytem for the wastegates and include a muffler if noise is an issue, but you'll be adding even more plumbing, complexity, weight etc to your system.
[Modified by Monty, 6:10 PM 2/13/2003]
