Throttle body hoses?
Old Jun 24, 2025 | 09:10 PM
cameron11j's Avatar
cameron11j
Default Throttle body hoses?
I feel they are suppose to be EVAP hoses/lines, when I follow it back, it goes under the intake and into the side of the throttle body. If I’m not mistaken they should be hooked up to the EVAP, but the EVAP already has tubing hooked up. The tubing that is connected to the throttle body is not connected to anything as you can see in the video. Very confused
File Type: mov
Old Jun 24, 2025 | 09:50 PM
vetteLT193's Avatar
vetteLT193
I can't see the video but based on description coolant lines?
Old Jun 25, 2025 | 12:31 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I think the bottom hose is just a vent hose.
Top hose might go into the right side of the purge solenoid. I can't really see if there's a hose on that side of the solenoid in your video.
If it's not, than it's also a vent hose. I think there are two. Don't remember if they were a Y coming off a single line or not.
Old Jun 27, 2025 | 08:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The loose top hose should go to purge valve, if it is the one coming from manifold vacuum.
The bottom tube is vent to atmosphere, it splits into 2 vent hoses.
The hose from throttle body should be going to passenger side valve cover.
Old Jun 27, 2025 | 09:03 AM
AGENT 86's Avatar
AGENT 86
1986 Emission
To Throttle body hoses?
