does anyone know... (wiring)
Old Mar 15, 2003 | 02:24 PM
want2drivemy85's Avatar
want2drivemy85
Default does anyone know... (wiring)
I am having trouble figuring out what wires are going to the plug on the shifter (auto). It is a 6 wire flat connector, labeled a b c d e f. i would think one of them is for the reverse lights, maybe one for the computer ffor lock up? not sure on this....can anyone give me a hand? A wiring diagram would be helpful ;) ......TIA
Old Mar 15, 2003 | 02:54 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: does anyone know... (want2drivemy85)
Ask Jimswhite92. He's got it on disc. :cheers:
Old Mar 15, 2003 | 07:10 PM
jimswhite92's Avatar
jimswhite92
Hey my 85 diagram is not very user friendly. Could you give me the colors associated with the plugs and I will try to check on the diagram.
Is E dark green with a white stripe and F yellow ?????
Let me know.... Jim
Old Mar 15, 2003 | 09:09 PM
want2drivemy85
Default Re: does anyone know... (jimswhite92)
Thanks for the responses! ok here goes..
a= black with white stripe
b= orange with black stripe
c= blue
d=lite green
e= drk green with white stripe
f= yellow
BTW i need to figure this out because i am swapping the auto out in favor of a 4+3, and need to get all the wiring straightened out.
[Modified by want2drivemy85, 9:09 PM 3/15/2003]
Old Mar 15, 2003 | 11:12 PM
hngacurv's Avatar
hngacurv
According to an 88 wiring diagram on an auto the DK BLU goes from the backup fuse to the transmission position switch and the LT GRN goes from the position switch to the backup lights.
[Modified by hngacurv, 11:12 PM 3/15/2003]
Old Mar 16, 2003 | 03:49 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Pin A is the black with white stripe and goes to ground at splice S212.
Pin B is the orange with black stripe and goes to the ECM pin B10. A and B make when in Park or Neutral. Not used in manuals.
Pin C is dark blue and goes to the TURN/BU fuse as said by hngacurv.
Pin D is lite green and goes to the lights as said by hngacurv. C and D make when in Reverse. These will need to be wired in to the 2 cavity connector (12015378) that will plug into your new 4+3s backup switch.
Pin E is drk green with white stripe and goes to pin A of the Start Enable Relay.
Pin F was I thought purple not yellow, but it should go to the S terminal on the solenoid and to the Cold Start Injector system through splice S206. E and F make when in Park or Neutral. These will need to go to the Clutch Switch so the starter will only run when the clutch pedal is depressed or you can connect them together and lose the safety feature. But ring this one out first, because of the color mixup, I can't be sure on this one.
Old Mar 16, 2003 | 09:59 AM
jimswhite92
Default Re: does anyone know... (Ray Quayle)
I concur. Wire F is yellow on my schematic.
Let me know if you need a copy.
Jim
Old Mar 16, 2003 | 06:42 PM
want2drivemy85
Ray- Thanks, thats the kind of stuff i was looking for!
Jim- If you could email me a schematic, i would be very greatful! Much easier to do this with a diagram in front of you.
Thanks again all!
To does anyone know... (wiring)
