Lowwering your C4
Old May 10, 2003 | 12:54 PM
Tolofou's Avatar
Tolofou
Default Lowwering your C4
My car has that switch that changes the ride wich is really cool but I would like the car to stance lowwer.. How do I do this and still keep the cool switch..Is it springs? I dont want to cut them unless thats the only way..
Rob
Old May 10, 2003 | 02:52 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: Lowwering your C4 (Tolofou)
You can purchase a lowering kit from a number of different vendors i.e. Ecklers, MAD, VBP, etc. Usually $25.00-$40.00
Lowering the rear is quite simple, you replace the stock bolts with longer bolts that are provided in the lowering kit. Takes about 10-20 min.
The front is a bit more difficult. In most cases, it requires you to remove the front spring and cut-off the stock rubber "snubs" which are about 1 1/2" in height. The kit will also contain polyurethane wedges which are approximately 1/2" in height. These are glued on to the spring where the stock "snubs" were removed. All in all, this takes 2-4 hours...depending on your mechanical abilities. If you have access to a lift, it will make the procedure alot easier. :cheers:
Old May 10, 2003 | 03:04 PM
Tolofou's Avatar
Tolofou
Default Re: Lowwering your C4 (Hardcorvette)
I dont mind to pay alittle more to get the goods. Who is the best to shop with and got the best goods.. And post a link too what you see..
Rob
Old May 10, 2003 | 04:00 PM
Hardcorvette
I purchased my kit through VBP...excellent quality. Although I'm sure the other kits are of similar quality.
Here is the link to Vette brake Products (VBP) http://www.vettebrakes.com/
Once there, do a search for "lowering kit" .
:cheers:
Old May 10, 2003 | 05:35 PM
Tolofou's Avatar
Tolofou
Sounds good. And thanks guys.. But how does it drop it with 2 bolts I can probly find in the Garage with Nylon lock nuts and 2 slabs of hard rubber poly. and how well does it work? Can I get some pics and has anyone not bought the kit did this there own..
I dont want to sound rude if I did.. But I just think this can be had for cheaper without suffering quality..
Rob
Old May 10, 2003 | 07:42 PM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Rob
You probably CAn fabricate your own "system".
Just make sure that you use the proper grade bolts in the rear.
KALE is offerinf a discounted lowering setup at http://www.kalecoauto.com/appear.htm
Old May 10, 2003 | 07:51 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Rob
40 bucks is cheap when you can trust the kit. Using bolts you "find in the garage" is a good way to guarantee disaster. Remember this is holding the spring on the car. Why get cheap here?!
Old May 10, 2003 | 08:10 PM
Tolofou's Avatar
Tolofou
Default Re: Lowwering your C4 (flyersfan1088)
O.K. but an inch is good? With these kits you can drop her how far? I will buy the kit and will see about this.. I have a lift here at the house full car and this should be a snap.. I just thought I had to get springs,spindels and shocks.. How is the camber after the drop? Notice anydifferent when laying down the pedal? More stiff or the same since nothing was changed but ride height..
Rob
Old May 10, 2003 | 10:25 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I did mine with some 9/16 alloy ready rod and a piece of my girlfriends nylon cutting board!! Total cost 10 bucks !!! :cheers:
Old May 10, 2003 | 11:31 PM
h rocks's Avatar
h rocks
Just go to Lowes and get the corresponding SAE sized grade 8 bolts (and locknuts), then get the thing aligned, as lowering will cause your rear toe to change.
Old May 11, 2003 | 11:27 AM
Phil-tha-Rush
Rob
convertibles tend to ride a little higher than coupes from the factory. (to allow clearance for the X brace)
Mine was lowered with one of the $40 kits mentioned above.
Check my ride hight in my sig.
It rides fine, and I dont think I would want it any lower. The rear actually bottoms out on a big bump, so could stand to be a little higher.
[Modified by Phil-tha-Rush, 10:30 AM 5/11/2003]
Old May 11, 2003 | 11:32 AM
Hardcorvette
Default Re: Lowwering your C4 (Phil-tha-Rush)
:lol:
Old May 11, 2003 | 04:37 PM
FastZR1's Avatar
FastZR1
Veteran: Marine Corps
If you can lower the front of the car in 2-4 hours.... that is great. You have to pull the entire front spring out of the car so there is a bit of work getting that out. It took me and a buddy about 6 hours to drop the front of my car and we had a lift. We were taking our time to measure everything right and so we didn't jack anything up. The end result looks great.
You will need an alingment too. You will see once you put it back together. As for a ride difference.... I really didn't notice one.
Old May 11, 2003 | 05:38 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Lowwering your C4 (fastzr1)
For the rear, it doesn't matter where you get the bolts, just get Grade 8 bolts.
They should have 6 little lines on the bolt head.
If you want to do it right, be sure to cut your spring retainers shorter, or buy new ones. These keep the spring located properly. Most people don't do this, but I haven't seen any cases of it causing trouble. But if you saw exactly what I'm talking about, you'd realize why its not right.
Old May 11, 2003 | 05:47 PM
Lord Odin's Avatar
Lord Odin
Rob
That switch is called Selective Ride Control (FX3). I have it, too, and love it. :cheers: Let me know how it goes because I will be doing the same this summer or this winter.
Old May 11, 2003 | 08:05 PM
Raistlin's Avatar
Raistlin
Default Re: Lowwering your C4 (Lord Odin)
I just finished lowering, ES poly bushing master kit and re-valving my bilsteins (FX3). It turned out really well. The car handles much better and the ride quality has improved. Before, the rear felt twitchy and loved to step out without much coaxing. After, the rear feels more planted to the road. I drove it that way for a couple days till I got an alignment and new Kumho MX's put on.
The alignment may be a bit radicle for the street, but I have never felt so confident running through turns. It goes where I want it to go, I don't have to fight it. I think it could stand to be a little stiffer, especially in the rear, so my next step might be a set of Z51 springs.
Body roll has been reduced even though I'm still running the stock anti sway bars and corresponding bushings. (26mm F, 22mm R)
Old May 12, 2003 | 09:30 AM
Tolofou's Avatar
Tolofou
I found a kit IM going to get :hurray:
Pics of before and after will be done.. Thanks to all..
Rob :thumbs:
Old May 12, 2003 | 06:35 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
The lowering kits available from Mid America.....or anyone else are just to much work to get....maybe 1/2" of lowering.......I used one on my '84, and was lucky to get 1/2" more lowering......to much work......for not!!!!!!!!!!
Just my thoughts.....
tony
:chevy :D :flag
To Lowwering your C4
