bin files
Old May 22, 2003 | 04:34 PM
devilfish's Avatar
devilfish
Default bin files
is it the same bin file for a 90 corvette 6spd as for my 91?
Old May 22, 2003 | 10:28 PM
tjwong's Avatar
tjwong
Default Re: bin files (devilfish)
Its definitely the same ECM Hardware, however there maybe minute differences in the actual programmed parameters with in the programming that resides in the BIN file itself. For instance you can take a 90 M6 prom and drop it into a 91 M6 and most likely the car will run fine. However there maybe some differences in the calibration btween the two model years. If you remove the MEMCAL from the ECM or look on the ECM label if the ECM is the original, there will be a 4 letter broadcast code for an example: ANHT is for a 90A4 car.
Old May 23, 2003 | 06:53 AM
devilfish's Avatar
devilfish
Default Re: bin files (tjwong)
ok i will check that and com back :)
thanks
Old May 23, 2003 | 11:15 AM
Red91C4's Avatar
Red91C4
Devilfish here is a photo of the sticker that is on the factory ECM the circle indicates the broadcast code. This ECM is from my 91 6spd, I have the BIN for this and I can send it to you if it's what you need.
This code is AXCN
[Modified by Red91C4, 10:17 AM 5/23/2003]
Old May 24, 2003 | 09:49 AM
devilfish's Avatar
devilfish
Default Re: bin files (Red91C4)
yeah is it for a 91 6spd? If yes, please mail it to me
v8mannen@hotmail.com
thanks
Old May 25, 2003 | 06:28 PM
devilfish's Avatar
devilfish
tt
To bin files
