How much hp gains with an X-pipe or even straight pipe?
Old 06-30-2003, 01:18 AM
blk95
blk95's Avatar
Default How much hp gains with an X-pipe or even straight pipe?
What the difference between and X-pipe and just installing two straight pipes instead?
Who has done straight pipes other than the xpipe? is there sound difference as well?
[Modified by blk95, 6:23 AM 7/1/2003]
Old 06-30-2003, 01:39 PM
_freakmonkeydogboy_
_freakmonkeydogboy_'s Avatar
Default Re: How much hp gains with an X-pipe or even straight pipe? (blk95)
:lurk:
Old 06-30-2003, 02:31 PM
vettek50
vettek50's Avatar
having redone the exhaust using x-pipe, no resonanators, no catalytic convertor, stright through to back , where i built a set of pipes resembling, the targa bolt on.
yes there is a signficant gain in power you can actaully feel..the only draw back is the noise. changed to dynaflow 3" in and 3" out,,racing muffler..installed it where the cat used to be.. no change in power or noise..
now lookin at replacing the dynoflow with flowmaster 3"in and out..but it has interior tubes to keep sound down...mite work..have appointment at muffler shop this afternoon...we will see if thr is less noise.
enjoy :cheers:
Old 07-01-2003, 01:26 AM
blk95
blk95's Avatar
I guess no ones has used straight pipe instead of an x pipe or resenator...
[Modified by blk95, 6:27 AM 7/1/2003]
Old 07-01-2003, 04:17 AM
ScottsLS3
ScottsLS3's Avatar
I put two striaght pipes in place of where my res was and it made a dramatic difference in the sound of the car, alot meaner then before. I didnt notice any difference in track times. I have the B&B 3 inch sysytem.
Old 07-01-2003, 05:25 AM
Darkness
Darkness's Avatar
Default Re: How much hp gains with an X-pipe or even straight pipe? (ScottsLT1)
strait pipes will give the most sound, the H pipe will give it a deeper sound and X pipe will give it a higher pitch kinda like the engine is reving higher than what actually is. Also H pipe will give a few more down low lbs-ft, the X a few more HP up top, but nothing major, just 1-2 hp difference, but both more than strait pipes.
:cheers:
Old 07-01-2003, 06:44 AM
LT-4 CE
LT-4 CE's Avatar
Location: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I just replaced my resonator with straight tubing. Sounds great, but have not been back to the track to know what gains, if any.
Old 07-01-2003, 01:02 PM
LT4BUD
LT4BUD's Avatar
Default Re: How much hp gains with an X-pipe or even straight pipe? (LT-4 CE)
Even if HP & torque stay the same, removing the resonator probably reduced your weight by 10 pounds or so. Every little bit helps & eventually adds to something significant.
The H-pipe I added to my B&B definately "mellowed" the tone a little bit.
Chris, did you retain you factory H-pipe when you removed the resonator?
Old 07-01-2003, 11:30 PM
blk95
blk95's Avatar
Default Re: How much hp gains with an X-pipe or even straight pipe? (Darkness)
:cheers:
Wouldn't straight pipes have more flow than Hpipe or Xpipe.....Heck i didn't even know they made an Hpipe, where do you get one of those...is that for a none LTmotors?
Old 07-01-2003, 11:31 PM
blk95
blk95's Avatar
Default Re: How much hp gains with an X-pipe or even straight pipe? (LT4BUD)
[QUOTE]Even if HP & torque stay the same, removing the resonator probably reduced your weight by 10 pounds or so. Every little bit helps & eventually adds to something significant.
Those resonators seem on the heavy side....
Old 07-01-2003, 11:42 PM
honas
honas's Avatar
I'm having a 3" X-pipe and cut-outs installed thursday morning. I'll let you know what it does. BH
To How much hp gains with an X-pipe or even straight pipe?
Quick Reply: How much hp gains with an X-pipe or even straight pipe?
