Help! Code #36
Old Sep 29, 2003 | 12:02 PM
Barrier's Avatar
Barrier
Default Help! Code #36
My car threw a code #36 "Airflow Sensor Burn Off Failure". According to the GM Manual this may point to a ECM failure and replacement. I have a spare ECM which is supposedly good (I bought it from a Forum member last year it is a #01227165 GM rebuilt).
Last year I had a code #33 & #34 I replaced the relays (burnoff and another) and the problem was solved. Has anybody had experience with code #36.
thanks
Barrier
Old Sep 29, 2003 | 05:37 PM
Barrier's Avatar
Barrier
Default Re: Help! Code #36 (Barrier)
Does any body have a clue???
Barrier
Old Sep 29, 2003 | 07:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Says in my manual to check
maf sensor
power relay
burn off relay
Could be one of those or just a bad connection at one of those.
:cheers:
Old Sep 29, 2003 | 09:19 PM
sailrmon's Avatar
sailrmon
I wouldn't put in a #1227165....they are prone to driver failure.The upgraded ECM is part# 16198259.Mine was giving me problems replaced with upgrade haven't had a problem since (3yrs).Know this doesn't answer your question but thought you should know this.Are there performance problems or just the code?
Old Sep 29, 2003 | 11:00 PM
NightRyder's Avatar
NightRyder
Default Re: Help! Code #36 (sailrmon)
hmm, well for as long as i remember... my car has always had that code 36... it doent seem to bother the car any, so ive been to lazy to mess with it.
the car still runs fine.
Old Sep 30, 2003 | 07:00 AM
Barrier's Avatar
Barrier
Default Re: Help! Code #36 (NightRyder)
I don't seem to have any drivability problems.
The dash check engine light will not go out. When I clear the code it goes right back on in about 15 sec. I hate that light, I get the feeling it's like a countdown and the car is going to self destruct momentarily. My '69 or '68 Corvette had a light on the dash with a pushbutton button that you had to press whenever you started the car it worked as a reminder to put your seatbelts on. I wish the check engine light was like that.
The spare ECM I have is a 165 model. I just want to replace the ECM in the car to see if it clears the code. If it does I'll get the updated ECM.
Barrier :)
To Help! Code #36
