Overheating Problems
Good luck!
As far as the fan problem, I'd hot wire the fan just to make sure it is working. Then trace back to make sure the wiring is okay. Next, hit your service manual. :cheers:
Your running temps should be lower. Main fan should kick in about 228' and aux fan(if you got 1) around 238. Apply a jumper wire from terminal "A" to terminal "B" on the ALDL connecter(underside of dash above right knee) and turn ign to on. This should start the main fan. If it dosen't run locate fan relay(on inside of inner fender near battery). Turn key on and apply ground to terminal "B" on the relay. If the fan runs there is a problem with ecm circuit. If it doesn't check for power and ground at fan. If none remove relay and check for 12 volts at terminal "D". If no voltage check fusible link near battery. If there is voltage check for 12 volts at terminal "C". If none there check fuse in panel. If all power is at relay connector jump terminal "A" to "D". If fan runs relay is bad.
:cheers:
:cheers:
WELCOME! :cheers:
I just went through this with my 86 this week. A paper clip bent into a "U" shape works well to ground the "A" "B" terminals under the dash (the two upper right hand terminals). I inserted the paper clip and switched the ignition to the "ON" position. Fan did NOT come on. With the paper clip inplace and the key in the "ON" position, I located the fan relay. I disconnected the connector and jumped the "A" and "D" terminals together (the far left and the far right terminals" The fan DID turn on. I replaced the fan relay for $10 at a local parts store and all is well now. Took me 10 minutes total. :thumbs:
Other suggestions to keep that heat in check.
1. Conisder a low temp fan switch. It will turn your fan(s) on at 200 degress and off at 185 degress instead of the 230ish factory range. EASY to install and inexpensive too. I got mine here http://www.madvet.com/shop?frame=3.138.944 If your state requires Bi annual Smog Inspections keep your stock switch on hand. They will not be able to get the car to reach temps much over 200 degrees for testing. It will keep that heat in check in traffic.
2. Consider replacing your stock 195 degree thermostat with a lower temp one. I went with a 170 degree thermostat from TPIS. It will lower coolant temps. These are readily available and range form 160 degrees up.
3. Consider drilling 4 small holes in your thermostat, per TPIS recommendation. (which ever one your may go with, factory or aftermarket.) I did this to mine and my temps IMMEDIATLY dropped from an average of 210- 230 to 175-200 with just this mod alone. The holes provide a continuous flow of coolant that will eliminate those high temp spikes. (Why the GENERAL did not think of or do this beats me.:confused:)
4. Ensure that the rest of the cooling system is in working order. Check hoses and wash off any debri from the front of the radiator and check the coolant level.
Do this and you WILL keep that heat in check.
My 86 seldom sees 200 degree plus temps.:D :D
Oh and last but not least. since you just got that Vette and new to the "Vette world" use that paper clip and this web site to clear any codes that your Vette might have had from the previous owner.
http://www.c4vettes.com/ecm.htm
It will guide you throught the simple process. It has proved INVALUABLE to me and I have cleared ALL the trouble codes in my 86 myself. She stays cool and perfoms like a son of a gun when I get agressive with her.
Good luck man
:D :thumbs:
[Modified by 86PACER, 1:30 AM 12/31/2003]
The tips given on this thread have been excellant.
Probably the first thing to check if your fan is not coming on is the fan fuse.
The fuse panel is accessible with the passenger door open; it is on the right end of the dash. Check the three amp. fuse labeled "C. FAN", it is on the right side of the panel in the second row.
If the fuse is blown, there is a short in the system; possibly a shorted (defective) fan motor.
Lots of luck and give us an update if possible.
Mark
Sensor may be bad also.
Are there any codes stored. 14 or 15 maybe
Check this link for reading codes
:cheers:
[Modified by AGENT 86, 8:25 AM 12/31/2003]
Here's a link to a tech tip that explains the process. https://www.corvetteforum.com/techti...D=53&TopicID=2
Ron
Do this next
1. Ground the "A" and "B" terminals again and insert the key, leaving the ignition "OFF"
2. Locate the fan relay (little black box right below the brake master cylinder.)
3. Unplug the electrical connector at the fan relay.
4. Turn the key to the "ON" position.
5. Connect a wire from the far left terminal to the far right terminal on the relay connector.
If the fan DOES come on again, you now know that the fan and the fan relay are both good.
You can splice a wire into terminal "B" of relay and run the wire to a switch in the cockpit. The other side of the switch goes to ground. This way you have full manual control of fan till you find the problem. You would probably choose to keep switch even after you fix the problem.
:cheers:
