Pressing my luck
Old Jan 3, 2004 | 09:56 PM
mitchcole's Avatar
mitchcole
Default Pressing my luck
Remember that post about how my corvette ran like the energizer bunny? All you guys who said I tempted fate were correct.
The water pump bit the dust.
It poured juice all over the opti. Then I pulled the pump off - and poured even more juice over the opti... The pump is on order and should be here on Tuesday.
Did I mention that the whole front of the engine is covered in oil and dirt? Looks like the seals associated with the timing cover have seen better days too...
I'm too broke after christmas to do this right.
So - sacrifice the virgin at the chevrolet temple so that my cheap fix may actually work.
Your half butt (it actually changed it to BUTT?) friend,,,,
Mitch
[Modified by mitchcole, 9:04 PM 1/3/2004]
[Modified by mitchcole, 9:05 PM 1/3/2004]
Old Jan 3, 2004 | 10:00 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Pressing my luck (mitchcole)
:smash: :smash: :smash: :smash: :smash: :smash:
Old Jan 4, 2004 | 03:25 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
yea, you can probably figure the opti will need to also be replaced... thats why I opted for my 87.... just my 2cents... :thumbs:
Old Jan 7, 2004 | 09:32 AM
mitchcole's Avatar
mitchcole
Default Re: Pressing my luck (vinnies87)
Fortune favors the foolish...
I replaced the water pump and left the greasy dirty wet opti alone. It fired off and runs great...
---Mr. Lucky :cheers:
Old Jan 7, 2004 | 09:39 AM
AGENT 86's Avatar
AGENT 86
:thumbs: Now go out and buy one lotto ticket. You only need one :D
Old Jan 7, 2004 | 09:41 AM
Goody's Avatar
Goody
The Opti doesn't die right away normally. It'll take a while before it rusts up some. Start saving money for a new Opti or find a cheap one and save it. It will happen, just a matter of when is all. Most change it while there to save labor, if you are doing it yourself then it really is overkill. I have never had to replace a waterpump on my 150K mile car, but did do the Opti once.
To Pressing my luck
