Need help replacing 84 antenna
Old Jan 25, 2004 | 05:58 PM
fritz48170's Avatar
fritz48170
5th Gear
Default Need help replacing 84 antenna
Do you know where to access the power antenna on an 84 ... do I get to it through the wheel well or through the rear deck? Any advice you have for me will save a lot of time. Thanks.
Old Jan 25, 2004 | 06:09 PM
bogus's Avatar
bogus
Default Re: Need help replacing 84 antenna (fritz48170)
rear wheel well... you have to remove the left rear tire... sorry.
Old Jan 25, 2004 | 08:47 PM
okinawa86vette's Avatar
okinawa86vette
Default Re: Need help replacing 84 antenna (bogus)
I did it on my '88 with out removing the wheel. In fact, I didn't even have to jack the car up. I did have to remove the trim under the hatch to get to the connections, but I was able to lay on my back and go up behind the wheel on the inside of the side of the bumper. It's actually not that bad a job if you have a friend help pull the wires through the hole in the body as you feed it through the bottom. I used a touch of dish soap to help the grommet get into the hole, but any grease should work fine.
Chris
Old Jan 25, 2004 | 09:06 PM
Brimis's Avatar
Brimis
:iagree:
Old Jan 25, 2004 | 09:32 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Remove the wheel and inner fender. Well worth the 5 minutes :smash:
Power connection is under trim beside hatch latch. Coaxial connection is under carpet, behind the trim on drivers side of cargo area.
:cheers:
[Modified by AGENT 86, 6:33 PM 1/25/2004]
To Need help replacing 84 antenna
