To high comp?
Old Jul 2, 2004 | 07:09 AM
devilfish's Avatar
devilfish
Default To high comp?
Hello
My engine is being rebuild as we speak. I was not planing on going FI. But a good deal on a procharger changed my mind, you know how it is
Well I wounder how high boost I can run "safe".
My engine:
SCAT 9000 nodular iron crank
SCAT fordge i-beam rods
PROBE light wieght forge pistons.
TF 23 cnc ported heads.
HOT CAM KIT
LT1 intake
The comp is 10:1.
Perhaps I should forget about going FI ??
[Modified by devilfish, 1:09 PM 7/2/2004]
[Modified by devilfish, 1:10 PM 7/2/2004]
Old Jul 2, 2004 | 10:51 AM
vvv90's Avatar
vvv90
Default Re: To high comp? (devilfish)
Maybe 10 psi well managed. That's about it though.
Old Jul 2, 2004 | 05:38 PM
tjwong's Avatar
tjwong
Default Re: To high comp? (vvv90)
I would say 6 PSI maximum boost at that compression ratio. Seeing how the average kit these days are produced for late model vettes and F bodies, and they run similar compression or more. But if you are building the engine now, and plan for a blower. Why not drop the compression to a blower friendly 8.5 or 9:1?
[Modified by tjwong, 2:38 PM 7/2/2004]
Old Jul 2, 2004 | 07:53 PM
LT1Vetteguy78's Avatar
LT1Vetteguy78
Default Re: To high comp? (tjwong)
I just got mine back to day and it runs 7-8 PSI when it was on teh Dyno..
Old Jul 3, 2004 | 12:46 AM
chriswtx's Avatar
chriswtx
Default Re: To high comp? (LT1Vetteguy78)
6-8psi with intercoolers and a good tune. Im in the same boat. 10.4/1 comp. I'm planning an 8psi kit later on. You could probably go 10psi with an aftermarket Dfi and alot of tuning, just alot more work involved(and$$)to make it safe.
[Modified by chriswtx, 11:48 PM 7/2/2004]
Old Jul 3, 2004 | 02:26 AM
StealDads67's Avatar
StealDads67
Default Re: To high comp? (chriswtx)
Yea like going into the motor to get the compression ratio lower....
Old Jul 4, 2004 | 12:40 PM
vvv90's Avatar
vvv90
Default Re: To high comp? (StealDads67)
Yep, that's about it, unless you're saying "tuning" as in pulling an a$z load of timing which will pretty much make 10psi useless for creating more HP.
To To high comp?
