I'm getting ready to install my LT headers and have been debating on whether or not to delete my EGR. Well, 2 days ago I set a code 32 and this made the decision for me. Is this what I need to do to delete it:
1-replace EGR with block off plate
2-connect vacuum hoses running to it
3-burn a chip that doesn't look for it
Is that it?
Actually you would disconnect the hoses, and if you have a 94 to 96 LT1 there are no chips to burn, but rather reprogramming of the PCM.
Can't say it's ever a great idea to remove something that reduces the combustion temps at cruise by about 500 degrees, especially if you have some miles on it. Burning a chip to ignore the code does nothing for the detonation it's likely to have and on some GM'S, there's some additional advance built into the tables for EGR, meaning that you run the risk of burning a couple of valves too.
I have run an EGR delete for years with no such problems. Of course, it you just ignore the code there might be problems but if the rest of the chip takes that into account when reprogramming the chip, it should be fine. There is more than one competent programmer outside the GM circles. Just my $0.02
I, too, would leave it intact and operational. The EGR system, by design, doesn't affect idle or WOT operation (that is, when working properly). As previously mentioned, it reduces pinging by reducing combustion temps. at "normal" speeds. Ported vacuum switches keep EGR from operating at idle speed thus keeping the idle "smooth". At WOT, there is insufficient manifold vacuum to "lift" the EGR valve against its internal spring diaphram.
