Desperately need HELP!!! Code 33 MAF
Anyway, after driving for about a minute the check engine light comes on. It comes up as code 33 mass air flow sensor. The MAF I have currently intalled is brand new as well as the power and burnoff relays. I also reset the TPS and IAC according to tech tips. Also, there are no vacuum leaks that I can tell. Can a bad vehicle speed sensor cause this by any chance? The one I have in there does not work and I don't get a mph reading on the dash.
I really need help quick! Is there anybody in the Chicago area that can look at the car for me??? Thanks everyone.
There is some diagnostics here.
Did you get my email reguarding digi dash ?
The oil pressure switch or the ECM, through control of the fuel pump relay, provides the voltage for the MAF. The MAF then gets 12 V for it's power relay which then provides 12 V to the MAF sensor.
So the MAF may not be getting powered up so it won't see the voltage it needs, the ECM then sets Code 33.
Circuit 998 has a pull up resistor but if it's open, the ECM will see high voltage as set Code 33.
Also, if the MAF sees the Burn-Off signal while the engine is running, a Code 33 will set.
Apply 12 V to the pump terminal on the ALDL ("G"). You should see 12 V at the MAF; if no voltage check to see that the fuel pump is running, if not repair the fuel pump circuit - could be a bad fuel pump relay not keeping the MAF powered up. Applying 12 V to the MAF ("G") will insure the MAF remains powered up.
There's a very long trouble-shooting procedure in the Shop Manual using a volt meter and test light to test all the circuits.
Hope this helps.
Jake
This is a cheap fix and may solve his problem
Jack
RACE ON!!!
I forgot to mention I also had my PROM reprogrammed. Is it possible there is something screwy in the programming???
-JRC-
Or was a test failure what started this thread?
Steve
NUckINg FuTS,
I'd be spending some time on that VSS. I think your symptoms merit it. Does the book address this? Good luck, and...
RACE ON!!!
The car starts farting and spitting as soon as that code comes on. There is no way it will pass in that condition.
I will try swapping out the VSS and see what happens. If not, then I will try a new computer. Desperate times = desperate measures $$$
RACE ON!!!
One is to borrow known good parts, like the ECM, PROM, MAF, relays. Install them on your engine and see if the problem is corrected. If the problem is corrected, then swap in your parts one at a time until the problem recurs; you'll then know which one is causing it.
There's got to be someone in your area that has the parts you need. I did if for a friend last year to help him sort out a problem he was having.
The second is to buy/borrow a ScanTool, Diacom, etc., to get real time data on what's going on.
Wish I could help more.
Jake
The only test I did on the ECM was at CKT 998. It was getting 5.7V with the ignition on. Also, I have access to a snap-on scan tool. What kind of data should I be looking for???
Start out by disconnecting the battery to clear the stored code.
With Diacom running on my laptop, I can monitor most of the critical sensor functions to see if any of them is out of range. There are about 27 different readings that I look at. I know from experience which readings I should be getting, but in the beginning I referred to my service manuals to see in what range the readings should be.
For your code 33 problem, you should look primarily at airflow and fuel readings.
According to the diagram someone else already posted (which is directly from the GM Corvette Shop Manual), here are the circuits to check when trying to find the cause of a Code 33:
120, 340, 450, 900, 993, 994, and 998. Ckt 465 (Fuel Pump Relay Drive)is also shown in the loop, but the manual doesn't show a checking procedure.
Do you know somone with a MAF you can borrow just to try? Even one from an 'F' body will work.
If you check everything there is to check, then it has to be the ECM that's bad.
Jake
