Ptk Project
Old Jun 30, 2005 | 11:10 PM
  #201
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Originally Posted by jersey jay
Well let me INSURE you that everything thing will be OK.
Remember baby steps 1st and no giant steps.
After you put about 1,000 hours of data logging in and road tunes your car will be dead on!
Like Doug said it's a learning curve.
No go eat your dry aged porterhouse.
yeah jay, you DONT wanna be a black angus and hang around me ill EAT YA
Old Jun 30, 2005 | 11:14 PM
  #202
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
  #203
1%r's Avatar
1%r
No way you a big boy and I'm not looking to be your next meal ticket as I think I would only be just a taste for you.
After I spoke to your Mrs. I'll bet you that she's 5'-5.2" in the are of 102-115.
Spill the beans how close am I?
Old Jun 30, 2005 | 11:59 PM
  #204
NICK YOSKIN
St. Jude Donor '08
no 5 3 12X
to much grisil just kiddin honey
Old Jul 1, 2005 | 12:03 AM
  #205
1%r's Avatar
1%r
Well whatever.
I hope both of you can hook up with us when we go to Little Italy and the Village next Friday night.
We would all be a wild crew as I see it.
I would offer to buy you dinner but then I'd be out of money for mods!
Old Jul 1, 2005 | 12:11 AM
  #206
NICK YOSKIN
St. Jude Donor '08
[QUOTE=jersey jay]Well whatever.
absolutely
Old Jul 1, 2005 | 12:21 AM
  #207
1%r's Avatar
1%r
Hey I'll keep you in the loop as always and yes we'll hook you up.
It all hangs on when Pete shows then were going to cross the river.
Old Jul 1, 2005 | 09:42 AM
  #208
BigLew's Avatar
BigLew
Default Hey Nick
thanks for the conversation, enjoyed the talk. Haave you or Jay found me a forged engine yet??
Old Jul 1, 2005 | 10:54 AM
  #209
Apipe's Avatar
Apipe
Shouldve converted to a cable TB and a BSIII and had Dale tune it....
You'd be driving it by now....GOTCHA NICK
I'm sure once its all tuned it'll be SIIIIIIIIIIIIIIIIIIIIIIIIIICK
Joel
Old Jul 1, 2005 | 12:17 PM
  #210
NICK YOSKIN
St. Jude Donor '08
Originally Posted by Apipe
Shouldve converterd to a cable TB and a BSIII and had Dale tune it....
GOTCHA NICK
Joel
hello joel!
i spoke w/dales yesterday
Old Jul 1, 2005 | 04:26 PM
  #211
NICK YOSKIN
St. Jude Donor '08
hello joel!
once the car is tuned ill order nitrous kit along w./alchy
Old Jul 1, 2005 | 04:27 PM
  #212
NICK YOSKIN
St. Jude Donor '08
oh and after that i will...
crap gotta go ill let you know later when i am done here
Old Jul 3, 2005 | 10:14 AM
  #213
Tomulrich's Avatar
Tomulrich
Anyone out there actually done a C5 BS3 with cable TB conversion?
I am working on mine now....so far I have the BS3 installed with wire harnesses for the trans and engine. I have the intake set up....next is the gas pedal modification....still figuring out how to do this.
I also had to by a converter for the BS3 tach signal. Our dash runs on 4 pulses per revolution. .....The BS3 has a 8 pulse per revolution output.......still need to wire the unit.
Waiting on the PTK turbo kit: PE61 turbos on a C5R block 427ci, 2000HP complete fuel system.....installing now. many many upgrades
If anyone has any input .........help is welcomed
Tom Ulrich
Old Jul 3, 2005 | 11:10 AM
  #214
NICK YOSKIN
St. Jude Donor '08
Tom Ulrich
yes!
CALL dale cherry@ berrel auto 215 659 8549.
he had twin turbo that had cable tb
Old Jul 3, 2005 | 11:12 AM
  #215
NICK YOSKIN
St. Jude Donor '08
yes!
if you call BS, dale WILL be perferred tuner/installer on their list.
Old Jul 4, 2005 | 12:56 PM
  #216
AVB's Avatar
AVB
Tom Ulrich
Wow, your car should kick ***!! It'll be a nice test for PTK.
What year is your car Tom?
Old Jul 4, 2005 | 01:34 PM
  #217
Apipe's Avatar
Apipe
Dale Cherry converted a car that had FAST on it....He installed a cable operated TB and then installed the BSIII for him,Talk to Dale 215 659 8549 or Leo from Neverlift about it...Like Nick said,If u call BIGGS,DALE WILL be the guy they reccomend to tune your car......
To Ptk Project
Old Jul 4, 2005 | 02:20 PM
  #218
Tomulrich's Avatar
Tomulrich
My car is a 1998....bought it in Nov 04 with 39,000 miles.
I have spoken to dale....in the past....from what I recall....his project isnt finished. I will not have any problems with the fabricating....I think my biggest problem is going to be the dash display reading "reduced engine power" I have turned all the codes off.....still there. Even if
I unplug the PCM completely it is still there.
I am having the intake pipes chromed and the exhaust housing silver coated.
specs
427ci C5R 8:5 compression PTK twin turbos 61mm
C5R main and head studs
Callies magnum 4.00 crank
Oliver Billet rods
Coated bearings
Mahle custom 36cc reverse dome coated turbo pistons, Hellfire .043 top rings.
AFR casting heads...CNC'd by ET performance...250cc intake runner...flowing in the 340's with great low lift numbers as well.
Manley Iconel exhaust valves
Cam Motion turbo camshaft grind dur 234 /232 116 lift .620/.620
FAST 90mm port matched intake, Nick williams Cable Throttle body
Kinsler high flow fuel rails
90lb Delphi injectors from Precision turbo (flow matched)
Fuel system BG 2000hp fuel pump -10 line from tank to -8 Y at the fuel rail. from the rails to a Magna fuel 1:1 boosted referenced regulator. Return line is -8. Also plumbed to retain the passenger side tank "jet pump".
Big Stuff 3 with trans control and data logging
E-Boost 2
3 Bar MAP
Electronic fuel pressure gauge
DTE stage 2 3:90 micro polished heat treated ,cold stabilized rear.
DTE brace
Fully built 4l60E transmission
Yank 3600 stall converter
Be cool double row radiator
Evans billet water pump with evans coolant...running 5 psi cap.
Exhaust B&B triflow with X-pipe
All meticulously installed...by me!
Old Jul 5, 2005 | 11:49 AM
  #219
Apipe's Avatar
Apipe
Its finished and the car runs 9.0's@155
Old Jul 5, 2005 | 12:45 PM
  #220
Shinobi'sZ's Avatar
Shinobi'sZ
specs
Oliver Billet rods
Coated bearings
E-Boost 2
3 Bar MAP
DTE brace
Nice...I have been waiting to see what the PTK will do non a big block...its going to put all others to shame.
