Ptk Project
Old Jul 17, 2005 | 01:26 PM
  #261
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Old Jul 17, 2005 | 02:18 PM
  #262
Shinobi'sZ's Avatar
Shinobi'sZ
Originally Posted by JZ 97 SS 1500
Let me know as soon as you get some # down. I have added Kevin to our Top Gun list on the site and I will add you as well. I have alot of other dyno sheets from customers, but their setups don't bling like your's, Kevin's, and Babala's.
Jose
Thanks Jose! I am looking forward to testing out the system on all 8 cylinders. Those broken spark plug wires were taking a toll on the dyno runs under 16lbs of boost. I have since swapped the plugs for some TR7 IXs and am rebuilding the spark plug wires. I also have an MSD ignition voltage regulator on standby to make sure the ignition is holding at 22vdc, if it for some reason starts to misfire again.
I am looking at a new run at 16# for base line without misfires, and then after that an 18-20# for testing.
Old Jul 18, 2005 | 05:55 PM
  #263
babala65's Avatar
babala65
Lookin good Nick
Old Jul 21, 2005 | 02:51 PM
  #264
VETZILLA's Avatar
VETZILLA
Originally Posted by babala65
Lookin good Nick
Old Jul 21, 2005 | 11:29 PM
  #265
NICK YOSKIN
St. Jude Donor '08
WELL its been a real educational tuning project!!
i have gone from knowing absolutely NOTHING to having a pretty good grasp i need to give thanks to quicksilver2002 for the help in educating me the tuning process and roadrebel for helping me configure things. anyway, i have a pretty nice data log that iam working with to get the ve tables in line. i will use some of the special features in the hp 2 bar eio, like the boost enrichment that works of map unlike pe that works of rpm which isnt always correct for fi guys.
i will run the car in closed loop.
as far as driveability the car is realllllllllll nice and still work to do
Old Jul 22, 2005 | 01:56 PM
  #266
AVB's Avatar
AVB
So you'll be running w/ 02's no maf right? Sounds good. How far into boost have you taken her so far?
Old Jul 25, 2005 | 07:50 PM
  #267
NICK YOSKIN
St. Jude Donor '08
well i havent been hanging on the board lately! been real busy with tuning.
well anyway i was data logging some nice sessions yesterday as it was the first day in a while where the humidity wasnt out of control!!!
the car is hands down smoothier then prevoius setup that ran maf. that set up was 231 237 598 112 caM and heads deal.
my current set up is the commanded af are set at 1.25 and the pe and boostenrichment is set at 1.246. open loop of course. the logs that i got show the car running in the non boosted kpas areas approx in the mid to low 13 a/f so that not to bad. i will probably change the commanded af to 1.13 which equals 13.1 af. 14.7/1.13=13.1 af. anyway, once the pe or the boostenrichment kicks in 105 and up, the af are running anywhere from 10.4 to 11.9 af. 14.7/1.246=11.8. so as you can see it's coming along
my plan, now is to adjust the ve tables in whatever cell that needs it until the WB02 reading equal whatever the pcm commanded are. when that is accoplished then i will reanable the closed loop and let the car run in stioch(spelling )
i must say though that it isnt that easy to "hit" all those cells in the histogram especially with and a4. need to hold it in first and rev it!
as far as boost levels yesterday i actually saw a boost spike of 9.9 psi but that was an anomally. i was consistantly seeing 7.5 psi and the car was pulling real hard.
i also wanna say that i had my concerns with turbo lag as that was a big discussion at one point on this board about this kit, i can honeslty say no frickin way!
i can only imagine how hard this thing is going to pull when its pushing 15psi and and i throw some timing in there.
please discuss your sd or maf tunings experience here!!!
Old Jul 25, 2005 | 08:00 PM
  #268
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
You already know my MAF and SD tuning endevors!
Old Jul 25, 2005 | 08:55 PM
  #269
NICK YOSKIN
St. Jude Donor '08
jay what your going through, i understand. it just like a bump in the road, there will be more
Old Jul 25, 2005 | 10:20 PM
  #270
1%r's Avatar
1%r
Naw I have any easy fix, I'll just go back to my LS tune which was
getting dialed in closer and closer if all else fails.
Old Jul 25, 2005 | 10:38 PM
  #271
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Good luck to you guy's...........as for me the 3 bar is in the trash now if they every come out with a piggy back unit........I will be all over it
Old Jul 25, 2005 | 11:00 PM
  #272
NICK YOSKIN
St. Jude Donor '08
jay youll work threw it, it most likely user error!!!
Old Jul 25, 2005 | 11:03 PM
  #273
NICK YOSKIN
St. Jude Donor '08
gary my car runs so smooth, what were the problems that you were having?
Old Jul 25, 2005 | 11:34 PM
  #274
1%r's Avatar
1%r
Gary,
Weren't you using a beta version when it first came out?
Old Jul 25, 2005 | 11:57 PM
  #275
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Jay...yes it was and that being said there were to many bugs to work out. When I get my engine back we are just going to go with LS1 edit. Time to let others do the R&D. I just want my ride back
Yep no R&D for me...........that why we are using a LS2 block whit dry sleeves to give us a thick sleeved 383..........I must be
Looks like 3 more weeks......I hope
Old Jul 26, 2005 | 09:27 AM
  #276
1%r's Avatar
1%r
Good luck with it Gary.
Edit will work but not as well as the SD tune you get with HP when you get into the higher boost levels.
