Ptk Project
Old Apr 3, 2005 | 09:15 PM
  #61
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
is apc one of the better quality aftermarket hoods on the market? i was told hood looks better in person too.
Old Apr 3, 2005 | 09:23 PM
  #62
AVB's Avatar
AVB
the fit is very good to me and my body guy ( just dropped it off last friday) says he's not seeing much prepping needed. Then again, this is the only hood I've seen prior to getting painted.
no complaints here..
Old Apr 3, 2005 | 09:30 PM
  #63
NICK YOSKIN
St. Jude Donor '08
Old Apr 23, 2005 | 10:45 PM
  #64
NICK YOSKIN
St. Jude Donor '08
well here is the latest...
its been hard to get everyone's schedule to jive but engine is all complete with all accesories on the front of the motor. i scrapped patriot heads and went with afr's 205. my compession is at 8.37 so should be able to really wick it up! motor, fresh trannie, tci's new billet 5 clutch stall and 3;15 hardened output rear are at the shop and will install tommorow.
the late 03 fuel system has been replace w/02 and 97 lines and lpe and msd bap. 60 motrons along with spped inc rails. the rails will not be installed as the passenger front part of the rail need to be shortened.
will drill and tap bottom front part of the rail for crossover.
i received my hp tunes 2 bar with enhanced io and will also receive from innovate their new lc1 an monday. its cool as i have optional input wire harness for blitz sbc so that way i can veiw a/f through it.
2 bar is going to be real cool willl data log in wideband on same program! just imagine the fun with blitz speed control and 2 bar map!!!
0 to 45 mph 5psi 45 75 8 psi 75 100 10 psi 100 1xx 14 psi
ps cannot wait till hp straightens out their 3 bar!!!!!!!
ill check in tommorow.
OH BY THE WAY
i have installation video for ptk kit, looks fricken easy if using current motor!!!!
Old Apr 24, 2005 | 12:20 AM
  #65
Bill Reid's Avatar
Bill Reid
Way Nick
Bill
Old Apr 24, 2005 | 03:44 PM
  #66
Sportsdude's Avatar
Sportsdude
Nick, Sounds like you are progressing well. So...., will the car be running by tomorrow? Can't wait on the completion
Old Apr 24, 2005 | 07:23 PM
  #67
NICK YOSKIN
St. Jude Donor '08
no !! ran into a couple of snags! throwing the motor in is the easy part , the little things ect. relocating and fabbing and cutting and so is what takes time. that stuff is all done
next weekend the car will be done then its tuning time.
btw the ls1 speed rails JUST fits! i will remove approx 4mm so that the alternator has a little bit of room. will i be ok if i have main feed that goes to a y then to rear of each rail then regulator on the front of the driver rail that runs back to return line?
Old Apr 24, 2005 | 09:11 PM
  #68
JZ 97 SS 1500's Avatar
JZ 97 SS 1500
Hope you like the video, we are thinking of adding videos to our kits for the installs instead of sitting down and making a written manual. Much easier and more helpful.
Jose
Old Apr 27, 2005 | 01:46 PM
  #69
NICK YOSKIN
St. Jude Donor '08
will have my innovate lc1 and blitz optional harness tommorow
Old Apr 27, 2005 | 02:38 PM
  #70
AVB's Avatar
AVB
If it fits, that's how I'm planning on doing it with a little bit of trimming most likely. I'm looking at the space at the rear of my rails and I know a -8 90 isn't going to fit.. then again, they're Aeromotives.
BTW, I just checked the PTK site and it shows my kit as SHIPPED!!!!!
Old Apr 27, 2005 | 02:57 PM
  #71
NICK YOSKIN
St. Jude Donor '08
what is the lenght of the driver rail??????? please let me know ASAP!!!
Old Apr 27, 2005 | 04:50 PM
  #72
Shinobi'sZ's Avatar
Shinobi'sZ
You guys hang in there, there hasn't been a single person yet that hasn't seen my kit and said, "holy shi t what the hell is that"...personally I kind of like that response. Well there was one guy who said, "that looks kind of busy"...kind of made question his sexuality but different strokes for different folks.
You are going to love how drivable the car is and how much power you are going to make. You guys both have 383's too...you will make more than me at 9lbs.
I can't wait until somebody buys the PTK kit for use as an all drag kit on a C5 with a solid rearend. The fact that you can swap in some TE64's and make 1400 hp is going to be sick. Thats the point where the full LT headers and T4 flange are going to make the biggest difference at.
Old Apr 27, 2005 | 05:05 PM
  #73
AVB's Avatar
AVB
Sorry bud.. I'm in the office making more money to spend. I'll check it tonight..
Old Apr 27, 2005 | 05:06 PM
  #74
NICK YOSKIN
St. Jude Donor '08
I HEAR YA!!!!!!!!!!!!!!!!!! TELL ME ABOUT IT!!!!!!!!!!
thanks
Old Apr 27, 2005 | 06:18 PM
  #75
babala65's Avatar
babala65
Hey Nick Greg called me today and told me they came in I told him I would call back later to order one. In the mean time I call Atom at innovate motorsports to make sure that there cable would interface with the blitz controller,he was unsure and said I should call Blitz. I just got off the phone with Blitz and he said that he did not think they would work together? Atom did say it would have to be A 5 volt input to work which the guy at blitz did say it is A 5 Volt input. Do you know anyone that has made them work together?
Dan
Old Apr 27, 2005 | 06:33 PM
  #76
babala65's Avatar
babala65
BTW, I just checked the PTK site and it shows my kit as SHIPPED!!!!! [/QUOTE]
I just checked PTK and mine was also shipped today
I just tried to call Dalton to get the tracking info
Old Apr 27, 2005 | 08:20 PM
  #77
NICK YOSKIN
St. Jude Donor '08
Dan
yes!!!!!!!!!!!!
the lc1 is 5 volt i am positive about this.
pretty much all widebands are 0 to 5 volts
blitz manual states that it need to be 0 to 5 volts and that what the lc1 kicks out.
do search on ls1tech
To Ptk Project
Old Apr 28, 2005 | 01:44 PM
  #78
AVB's Avatar
AVB
thanks
Hey Nick,
On the Aeromotive rails, the distance between the outer injector and the tip of the rail is about 1".. on each end and on both the driver and passengers side.
Last nite I got the -8AN feeds on at the back. It was a bitch and required dremeling out the back wall (water channel under the wipers) for clearance.. I used an 8Oring to 8male 90*coupler on the drivers side. Passenger side I couldn't do the same cause it sits a bit more forward and the stiff braided line wouldn't clear the manifold. I had to use a normal straight Oring to 8male coupler and 90* hose end to set the hose further out (or back in this case). Rubber hose would most likely allow to use the same fittings on the PSR as used on DSR.
Basically, it's not gonna happen w/o a dremel cause machining the rail, getting right up to the injector I don't think is going to be enough.
Old Apr 28, 2005 | 03:06 PM
  #79
NICK YOSKIN
St. Jude Donor '08
received a bunch of parts today!! like santa claus was here
tci's new billet covered 5 clutch lock up and innovate's lc1 lambda.
ill takes some pics tonight.
Old Apr 28, 2005 | 03:36 PM
  #80
flynbludream's Avatar
flynbludream
Originally Posted by Shinobi'sZ
Well there was one guy who said, "that looks kind of busy"...kind of made question his sexuality.....
ROFLMAO
