dyno date
Old Sep 29, 2005 | 04:53 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default dyno date
well i am set up for friday night to rent the dyno. i let you know #'s
Old Sep 29, 2005 | 05:07 PM
RoadRebel's Avatar
RoadRebel
Good Luck..May the "Force" be with you!
Phil
Old Sep 29, 2005 | 05:46 PM
AVB's Avatar
AVB
Hey Nick..
It'll be great to see where your at with your setup. How's the fuel/duty cycle situation? I'll assume it's been taken care of. If so, what specifically took care of it.. boost referencing the regulator or the addition of the bosch unit?
Just so because I believe the worst thing is being uninformed, here's a link on ls1tech, in case you hadn't seen it. It's on how bad things can get w/ no fuel and higher boost. Pretty confident 20psi is doable but just don't get to the point of going higher just for kicks.. At least wait for mine to get there.
Old Sep 29, 2005 | 07:14 PM
NICK YOSKIN
St. Jude Donor '08
phil thanks! they're ramped up quicker. drove around the other night with pressure guage and was at max @ little before zero vacuum.
arnel i will run as much boost as the duty cycle will allow. i bought used/new bulkhead assembly and will install bosch 420 internal in the stock bucket. my current setup will not keep up with the demands that ref reg would put on it, but i think the bosch will .
btw i have alchy now so
Old Sep 29, 2005 | 10:23 PM
SS930's Avatar
SS930
So are you going to be hitting the rollers with the new Bosch pump tomorrow?
Old Sep 29, 2005 | 11:31 PM
Z06VET's Avatar
Z06VET
Good luck . I hope it blows the dyno apart .
Dan
Old Sep 29, 2005 | 11:33 PM
JZ 97 SS 1500's Avatar
JZ 97 SS 1500
I better see some 4 digit numbers posted.....
Old Sep 29, 2005 | 11:36 PM
mdhmi's Avatar
mdhmi
I don't see what the big deal is in running race gas at that hp level. It's really not much more expensive than 93/94 octane. I can't imagine blowing up my forged motor to save a few hundred bucks a year in fuel.
Nick - whatcha shootin for? 800?
Cheers,
Mark
Old Sep 30, 2005 | 12:05 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Good luck on the dyno!!!
JB
Old Sep 30, 2005 | 12:29 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
at least... cant wait to hear Nick, good luck
Old Sep 30, 2005 | 12:35 AM
Shinobi'sZ's Avatar
Shinobi'sZ
You better do good Nick, I am scheduled for retuning next week...and hopefully with no misfires I will be able to see what my fuel system is capable of supporting..with relation to boost that is.
Old Sep 30, 2005 | 03:49 AM
Sportsdude's Avatar
Sportsdude
My guess is 850rwhp/900rwtq
Old Sep 30, 2005 | 09:02 AM
NICK YOSKIN
St. Jude Donor '08
I'd be in seventh heaven with those #'s!
remember A4 guys
Old Sep 30, 2005 | 09:48 AM
JZ 97 SS 1500
Nick you need to make our Top Gun list...hehe.
Old Sep 30, 2005 | 09:57 AM
slotsofun's Avatar
slotsofun
WHOOAAAAH!
Old Sep 30, 2005 | 10:08 AM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
remember A4 guys
I forgot it's an A4.
My crystal ball says 430/485 hp/tq
Don't blow it up tonight so we can have some fun next weekend.
Old Sep 30, 2005 | 01:07 PM
NICK YOSKIN
St. Jude Donor '08
Cheers,
Mark
mark as much as the injectors will allow i guess. i cannot turn up pressure as current fuel system will not sustain. will be installing bosch #bos 420 soon. with that pump ill be able to run ref and hopefully help the injectors.
i'd like to see anything in the low 7XX.
To dyno date
Old Oct 1, 2005 | 03:49 AM
Sportsdude's Avatar
Sportsdude
I'd be in seventh heaven with those #'s!remember A4 guys
Nick, I'm sure whatever the number is, you have one fast Vette....not only fast but one awesome looking ride that has "street" maner. I'm still saving for my PTK TT or A&A TT ATI P1 will have to do for now until the pennies become $$ enough for TT. Thanks for sharing your experiences and taking the time to answer my questions
Old Oct 1, 2005 | 09:03 AM
NICK YOSKIN
St. Jude Donor '08
well got home @ 12.:30 last night!
it went well but basically ran outa time. much more time is needed.
here are the stats:
a/r ran as low as 9.4 up to 10.5
boost was approx 12psi
timing was only 15*
injectors 19.5m/s
loosing fuel pressure
rwhp was 631
tq was 69X
i am real happy with that, boat load of power left but not until i get my bosch 420 and referrence my regulator. there was no reason to keep going
ill post dyno later todays!
btw the curvers where as flat as Kansas
Old Oct 1, 2005 | 11:18 AM
Apipe's Avatar
Apipe
Who tuned it and where did u tune it...
Those are very good numbers for the 1st time on the rollers...
