engine setup for 18psi
Old Feb 28, 2006 | 05:41 PM
motomafia's Avatar
motomafia
Default engine setup for 18psi
Need to know a good engine head combo for running around 18psi... dont want to worry about it breaking?....... what internals to run and injector size?? thanks guys!
Old Feb 28, 2006 | 05:48 PM
BlownV6's Avatar
BlownV6
For 18psi?
8:1 compression
LQ9 iron block
Any forged rod/piston combo
Any 225cc head out there - I like the DART's.
Old Feb 28, 2006 | 05:50 PM
motomafia's Avatar
motomafia
Dont want iron block though... need to keep alumn...... is a eagle crank not a good idea?
Old Feb 28, 2006 | 06:01 PM
BlownV6's Avatar
BlownV6
Eh.. 18Psi and stock block may not mix very well for long.
Old Feb 28, 2006 | 06:03 PM
mdhmi's Avatar
mdhmi
You shouldn't need to run 18 lbs to make sick power, in my opinion. An AL 346 will hold that type of power.
Mark
Old Feb 28, 2006 | 06:10 PM
AVB's Avatar
AVB
I'll tell you what I run..
408 iron.. I wouldn't run an aluminum unless it was setup by W2W or an outfit whose run em and not just once. Most of the builders I spoke w/ don't have a problem w/ Eagle cranks. Hell.. even a stock crank can support more than we can currently throw at it. Something that was explained to me an I thought confirmed what I wanted to do...
Nitrous puts the most stress on a motor.. 2nd is a supercharger and then comes turbo's. I run an Eagle.
The rods are Callies H-Beam and ARP all over.
Heads are a ported and flow better than a set of LQ9's... more important though is that they are a good match for my mild cam.
Arnel
Old Feb 28, 2006 | 06:12 PM
motomafia's Avatar
motomafia
Yea I mean I dont need a ton of CI .... and need to stay aluminum... so maby stick with 347 or go to 383.... I dunno.... how much for a set of the dart heads ... and should I get them ported or are they good to go out of the box?
Old Feb 28, 2006 | 06:32 PM
chriswtx's Avatar
chriswtx
What about running a forged LS2 aluminum short block??
Old Feb 28, 2006 | 06:42 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
These guy's are telling you right. To set up a block to handle 18+lbs you are going to get into some money. My LS2 408 it set up for 20+lbs
It is a darton sleeved block, mains and all the goodies (big bucks) the problem is we can't get it to stick with 16lbs of boost (on the dyno) so what the heck is the point I think we will end up with 800rwhp on pump gas when I get better tires but it is more than a joke(spinning) now. Anyway it can be done but it is not cheap
Looks like I am going to go for a little ride tomorrow
Old Feb 28, 2006 | 08:24 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Originally Posted by Z06GMAN
These guy's are telling you right. To set up a block to handle 18+lbs you are going to get into some money. .......
I had mine (346) at 16#'s but turned it down because it's a constant challenge just to put down a full 12#'s on the street unless it's just for bragging rights on the Dyno or a dedicated track car with wrinkle walls. Another question, are you really ready for the $$$ you'll have to sink into the drivetrain? Just ask roadrebel about his driveline adventures at far less psi.
Old Feb 28, 2006 | 10:51 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
well not sure if any of the above responces have personal pushed 18psi. i can tell you from my personal experience, i've run 18 psi.
i dont have anything fancy, minus my head studs. ls1 block stock crank manley h beam rods, lunati pistons(off the shelf) 228 224 588 580 115, afr 205 out of the box, arp main studs, arp L19 head studs and thats about it. i also run SD which is not the norm either but i personal love. it must be working well as i have yet to hear any c5 with 17 dr go as fast as i did. 145 mph @ 9.9 isnt to shabby for self tuned.
Old Feb 28, 2006 | 11:04 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Yeah but you have to admit. Running it once compared to running it consistantly are 2 different animals. I'm sure there are more than a few cars on this forum that could run 18psi once or twice without it letting go. But just how many times you can run it no one knows.
Old Feb 28, 2006 | 11:21 PM
NICK YOSKIN
St. Jude Donor '08
running 18psi at the track is totally different then running on the street.
i have run 16 psi regularly on the street
not sure i have to admit to anything.... how do you know i ran it once?sorry, but like 8 runs.
well more important then psi is track #'s. any of those cars on the forum run 145mph @ 9.9 w/60 ft 1.789 on 17 dr?
Old Feb 28, 2006 | 11:57 PM
2MuchRiceMakesMeSick's Avatar
not sure i have to admit to anything.... how do know i ran it once?sorry, but like 8 runs.
How much did your car dyno at 16psi?
Old Mar 1, 2006 | 12:11 AM
motomafia's Avatar
motomafia
i expect to spend some coin, just need to know best direction to go in.. i HAVE to keep a alum block... And would like a setup i dont have to worry about it breaking/....
Old Mar 1, 2006 | 12:29 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
I would save your money for the new alum "WARHAWK" WORLD PRODUCTS BLOCK coming out in a month or two and WORLD PRODUCT HEADS (very similar to C5R Heads), that can both accomadate both large cubic inches (if you want to go large) and HUGE BOOSTED HP (18lbs should be no problem) mainly becaue the WORLD PRODUCT HEADS won't LIFT and be blown off by the HUGE BOOST, b/c they allow for eight (8) head bolts to keep them firmly in place, where all your other options out there for you only allow for 6 head bolts to keep the heads firmly in place.
The biggest problem you will have with the current options on the market making 18 lbs of boost is keeping the heads from lifting and the superstrong WARHAWK WORLD PRODUCT BLOCK (which was all the rage at SEMA) will cure this problem by allowing eight head bolts to hold down the WORLD BLOCK HEADS. Per my recent GM High Tech magazine, figure around 4,000.00 for a fully prepped bare WARHAWK Block (much better than the $6,400.00 for a C5R block)!!
Old Mar 1, 2006 | 12:34 AM
NICK YOSKIN
St. Jude Donor '08
never did..trapped 142.XX though
To engine setup for 18psi
Old Mar 1, 2006 | 12:37 AM
NICK YOSKIN
St. Jude Donor '08
Originally Posted by BLOWN ECS Z06
I would save your money for the new alum "WARHAWK" WORLD BLOCK coming out in a month or two and WORLD BLOCK HEADS (very similar to C5R Heads), that can both accomadate both large cubic inches (if you want to go large) and HUGE BOOSTED HP (18lbs should be no problem) mainly becaue the WORLD BLOCK HEADS won't LIFT and be blown off by the HUGE BOOST, b/c they allow for eight (8) head bolts to keep them firmly in place, where all your other options out there for you only allow for 6 head bolts to keep the heads firmly in place.
The biggest problem you will have with the current options on the market making 18 lbs of boost is keeping the heads from lifting and the superstrong WARHAWK WORLD BLOCK (which was all the rage at SEMA) will cure this problem by allowing eight head bolts to hold down the WORLD BLOCK HEADS. Per my recent GM High Tech magazine, figure around 4,000.00 for a fully prepped bare WARHAWK Block (much better than the $6,400.00 for a C5R block)!!
dont hold your breath.....i am betting mid summer....
no reason unless your car is back halfed
Old Mar 1, 2006 | 12:48 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
No where in this thread is track numbers except the ones you keep talking about. This thread is about PSI and what is required to run it. I am saying that darn near ANY forged motor with the proper tuning can run 18psi. Heck, probably more than that. For how long is a different question all together.
Did your car run AWESOME numbers??? Hell Ya!!!! But thats already been said/discussed in the F/I section about 422,312 times..
Even though my motor is being built to withstand MUCH more boost, I will probably NEVER see those times. Hell, I cant even race..
Old Mar 1, 2006 | 02:18 AM
flynbludream's Avatar
flynbludream
You post doesn't really make sense if you are concerned about breaking stuff. With that much boost you are probably looking around at least 800hp, so even if you keep your motor together, you are probably going to be breaking everything else.
