post AIT
Old Aug 23, 2006 | 10:03 AM
TaTommy888's Avatar
TaTommy888
No alky, just the stock STS setup at 7lbs.
I see 5-10 degrees above ambient. Outside temps have been in the 80s lately...
Tommy
Old Aug 23, 2006 | 12:25 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
doug
Old Aug 23, 2006 | 12:30 PM
Earl H's Avatar
Earl H
Recent 1/4 mile runs (based on EFILive Logs):
Ambient at ~ 75-77d
Starting IAT's (immediately after burnout): 90d
Endo of the pass: 57d
Old Aug 23, 2006 | 12:45 PM
AVB's Avatar
AVB
Nick,
I know you know this man but.. you have an intermittent issue and the only way to deal w/ that is to know what of what you've got is good.
Confirm all wiring/connections are good. Even a cold solder, flakey crimp-on or bad ground can work some times. Then there's, as we talked about, obstruction.. incoming and pressure side needs to be checked. Hell, if you could borrow components to confirm whether things improve that would make things go alot quicker.
I know it's a PIA but I just don't want to see you replacing the whole system and having the same problem happening.
Good luck
Old Aug 23, 2006 | 01:12 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Originally Posted by AVB
Nick,
Good luck
Nick, just like I told you to do, check one item at a time first starting with all your connections.
Old Aug 23, 2006 | 02:09 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
99 degrees after burnout at the beginning of the run and 64 degrees at the top of 4th. This is on my 11.26 run. Single nozzle ECS/Alky kit 9 psi.
Old Aug 23, 2006 | 04:53 PM
NICK YOSKIN
St. Jude Donor '08
Nick,
Good luck
arnel and jay,
i will start w/connections. if all checks out i will put gauge on it. if that checks out then i will reroute lines in the event that they maybe vapor lockin. actually the fisrt thing ill do is use my lazer temp. gun to see if the line is seeing 150* i dont think its vapor lockin as every time that i have hit the test button i have seen my ar drop. this is no matter how hot/heatsoak the engine bay has gotten.
Old Aug 23, 2006 | 05:00 PM
NICK YOSKIN
St. Jude Donor '08
Ambient at ~ 75-77d
wow.....i thought my car was working on the first run....66 being ended 8X
Old Aug 23, 2006 | 05:38 PM
QuickSilver2002's Avatar
QuickSilver2002
I'm really surprised you guys like spraying the IAT sensor. I found that to be problematic and inconsistent from a tuning perspective. The readings of a wet sensor just make you think you have really good IATs. Not a good approach IMHO.
FWIW, I would usually see 20-30* rise in IAT by the end of the 1/4 mile with a stock dry sensor. The stock sensor pretty much sucks from a response perspective and I recently ordered a replacement that is suppose to work much better.
Old Aug 23, 2006 | 10:35 PM
NICK YOSKIN
St. Jude Donor '08
well here is the deal.
i hooked up a home made pressure gauge using a mechanical boost gauge w/regulator, some l brass fitting and some vacuum lines.
i applied compressed air into the regulator and from there it went into the map sensor that controlls the pump. the gauge read 4 psi nothing 8 nothing 10 nothing(held it there for over 10 seconds) then 15 psi at which it started discharging meth.
well with this there is no doubt that it isnt a bad connection or vapor lock.
bad brain or pump, i am betting bad pump.
Old Aug 23, 2006 | 10:47 PM
1%r's Avatar
1%r
You need a new pump, I swear it as I heard the whole thing over the phone, it's not a vapor lock issue.
Get Julio on the phone and make him belly up to the bar with a new pump instead of rebuilding yours for a 3rd. time!
Old Aug 24, 2006 | 06:43 AM
Earl H's Avatar
Earl H
Nick did you test the voltage from the MAP sensor? I've had one go bad.
Old Aug 24, 2006 | 07:13 AM
  #33
7LitreC5's Avatar
7LitreC5
With ambient around 70 my Vortech would see about 125 after a pull to the top of 4th gear. With the RMCR/Vortech I would see about 135.
Old Aug 24, 2006 | 08:17 AM
  #34
NICK YOSKIN
St. Jude Donor '08
no....will do tonight. i actually have a spare one if needed.
Old Aug 24, 2006 | 08:50 AM
  #35
onfire's Avatar
onfire
Run down to Advance auto, Autzone, etc and buy a Mityvac for $30. It will make all future tests cake. It's a hand held pump with a built in gage that lets you apply vac or pressure....very simple to use.
Old Aug 24, 2006 | 09:42 AM
  #36
NICK YOSKIN
St. Jude Donor '08
thanks....will do. yeah my buddie lent me this one i used.
