post AIT
Old Aug 22, 2006 | 04:58 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default post AIT
let me know ambient and approx how long your foot was in the pedal
Old Aug 22, 2006 | 09:45 PM
NICK YOSKIN
St. Jude Donor '08
well i guess there arent alot of self tuners here
well what is acceptable ait on a 1/4 run?
i would guess that 175 wouldnt be good..
NOTHING CHANGED from two nights prior....ait were 117.
same trim settings same alky approx same ambient temps....
when i get some time ill put a gauge on the pressure side of the pump to get a reading.
Old Aug 22, 2006 | 09:56 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I have some data Nick, but it's real old. I have never seen 170+ IAT. You're measuring after the intercooler, right?
Old Aug 22, 2006 | 10:21 PM
NICK YOSKIN
St. Jude Donor '08
yup and after the alky too.....
17X is not good but why the difference from one night to the other?
Old Aug 22, 2006 | 10:25 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
anywhere from ambient to -20 below outside ambient last time I logged with the alky spraying.
IOW 100 outside ambient my iats were 80-100 depending on how much I was spraying.
Old Aug 22, 2006 | 10:32 PM
onfire's Avatar
onfire
A 60 degree delta suggests your alky isn't working.
At 16psi I get 165F at the end of a 1/4 mile without alky....much lower with the alky.
Old Aug 22, 2006 | 10:37 PM
NICK YOSKIN
St. Jude Donor '08
jay that is a little unbeliveable!! how long of a blast? 0 to 145 is stout
i ran my car 0 to 145 and the gain was 3/4 to max and my ait were 17x.
that is horrible for sure but the other night i ran the same speed and temps got to max of 11X. that is more resonable. once again nothing was adjusted nor a different type of alky was used. vapor lock? doubt it ambeint temps the same....... alcky level in the tank both were full..
Old Aug 22, 2006 | 10:38 PM
NICK YOSKIN
St. Jude Donor '08
MY POINT EXACTLY!
ITS PUMPING ALKY as when i hit the test button i see ar drop but that doesnt mean the pump is making the proper pressure when need. i wanna put a gauge on it but why??????? i already know that it worked the other night now it seems to not work?
cannot be electrical as like i said it sprays but.....not enough. turn up the gain? no like i said it was fine and no adjustments
Old Aug 22, 2006 | 10:45 PM
1%r's Avatar
1%r
Outside ambient when I logged was 85 and the blast was from 40-130 with the tires spinning. How long of a blast, not that long as you well know.
Old Aug 22, 2006 | 10:46 PM
2001-WS6's Avatar
2001-WS6
I prefer -15 to +20 over ambient on my 95 degree track days. Some call it maize... I call it A2W.
Ice it if you got it.
That's just a jogging 1/4 pass at 12.5lbs.
Rick
Old Aug 22, 2006 | 10:55 PM
NICK YOSKIN
St. Jude Donor '08
[IMG][/IMG]
Old Aug 22, 2006 | 10:57 PM
NICK YOSKIN
St. Jude Donor '08
well if that is true then something is wrong...again
Old Aug 22, 2006 | 11:00 PM
1%r's Avatar
1%r
I'll just have to call you then now.
Old Aug 23, 2006 | 12:00 AM
NICK YOSKIN
St. Jude Donor '08
just ran the car and iat started out 66 and ended at 82. run was 0 to 144. **** turned up all the way and ambient 66.
then 3 minutes later ran the car again and the ait were 72 at the start and spiked to 129. that run was from a roll at 30 mph to 122.
well its clear that the that it wasnt working on the second run.
what could be the issue?
Old Aug 23, 2006 | 12:42 AM
1%r's Avatar
1%r
Ce your alky no worky Senior.
It's got issues for sure be it the pump, brain, gain **** or a loose wire but what it's doing is just not right. I would look at all the connections first to make sure that they aren't the issue. From there it's a crap shoot so I would call Julio and have him send a whole new kit and just return this one being you've has problems in the past.
Old Aug 23, 2006 | 01:14 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
We logged my IATs on a full dyno pull, and they ended up peaking about 15 degrees below ambient at the top of the run!!
JB
Old Aug 23, 2006 | 01:16 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Are you running SD? If not, the fact that your IAT sensor is after the alky may have helped suppress detonation in that the higher IATs likely retarded timing more than you would ordinarily see with the alky on.
To post AIT
Old Aug 23, 2006 | 09:00 AM
onfire's Avatar
onfire
Run it back to back with the alky off both runs.
Old Aug 23, 2006 | 09:38 AM
NICK YOSKIN
St. Jude Donor '08
jay, yeah i am not happy....as you know i've had problems in the past....
yeah its starting to get old!
Old Aug 23, 2006 | 10:01 AM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
http://forums.corvetteforum.com/show....php?t=1445575
I did a pull this morning.. it was about 70, 73 IAT... car moved down to 70 on a 3rd gear pull. No room for a 4th gear pull. It is a bit hard to tell when the tires are spinning.. you really need that pull through a full gear.
As we discussed... 7 psi turn on, full pressure at about 13 psi. When I vary boost I get varied alky, as expected.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
