dreaded 1514 code
Old Sep 30, 2007 | 02:57 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default dreaded 1514 code
well i turned the boost up to 13.X psi and bam....1514 code.
i have the table maxed out out 4.10.......what to do?
w/19.2 psi on the last set up i never popped that code. well one thing is for sure i'm flowing a boatload more g/per cyl
any suggestions?
BTW posted here as it a FI/tuning issue
Old Sep 30, 2007 | 04:26 PM
tazinhawaii's Avatar
tazinhawaii
Nick,
I had the exact same problem and went through what it sounds like you are. I had to bring the fuel injector flow rate down (trick the compputer into thinking you have smaller injectors) and then decrease the VE numbers. I found the answer on some other board once and it saved me. Basically,, once the VE numbers cause calculated airflow to reach a certain value, the computer isn't able to process it, and throws the code. So by triccking the computer to think it has less airflow, but making up for that by also making the computer think there are smaller injectors. For me, I have 95# injectors, but have the numbers for ~65# injectors. I hope this helps. It is a tedious process as well, if you already had your VE numbers tuned in pretty well before as you then have to retune.
Derrick
Old Sep 30, 2007 | 05:39 PM
NICK YOSKIN
St. Jude Donor '08
Originally Posted by tazinhawaii
Nick,
Derrick
SWEET!!!
ill give it a shot...makes sence
Old Sep 30, 2007 | 09:34 PM
RJW's Avatar
RJW
From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
it's in a sticky on the hpt board
Good luck with it
Old Sep 30, 2007 | 10:36 PM
NICK YOSKIN
St. Jude Donor '08
Good luck with it
were?
i ll start lookin
thanks
Old Sep 30, 2007 | 11:06 PM
RJW's Avatar
RJW
St. Jude Donor '08
Originally Posted by NICK YOSKIN
were?
i ll start lookin
thanks
http://www.hptuners.com/forum/showth...6221#post86221
You already know this...but there is mention on having to tweak IFR/VE tables..which was mentioned above.
Good luck with it...doesn't sound too hard...if it works
Old Sep 30, 2007 | 11:24 PM
NICK YOSKIN
St. Jude Donor '08
ill cut the ifr table by 20% and the ve by 15%
leaving 5% for a little safety. ill see if that helps..if not ill try 5% at a time until......................
Old Sep 30, 2007 | 11:33 PM
NassauBlue98's Avatar
NassauBlue98
... Basically,, once the VE numbers cause calculated airflow to reach a certain value, the computer isn't able to process it, and throws the code...
Anyone know what that "certain value" is?
For a while I was pondering how Nick could be flowing 4.10 gm/cyl as rough calculations told me that would be somewhere in the 2000 engine hp range.
Old Sep 30, 2007 | 11:39 PM
NICK YOSKIN
St. Jude Donor '08
not sure how it does the caculations....i was seeing 2.09 g/per cyl @ 13.X psi when it set code
Old Oct 1, 2007 | 12:09 AM
stc2002's Avatar
stc2002
again, why not just disable SES for 1514 code? Worst i can imagine is throttle getting stuck open.. then just shut down.
Old Oct 1, 2007 | 12:20 AM
RJW's Avatar
RJW
St. Jude Donor '08
Disabling ses...so you have no light, but wouldn't it still go into reduced power mode???
Asking, cause I had to cure a 1514 related problem today on a car with a fair sized cam and maggie.....I didn't think that disabling the light would cure anything???
Old Oct 1, 2007 | 01:55 AM
FRCTony's Avatar
FRCTony
Are you sure you have the table set to 4.1?
Old Oct 1, 2007 | 07:39 AM
stc2002's Avatar
stc2002
NO, disabling SES would keep it from going to reduced power mode. Setting no MIL light would make it just not show a check engine light.
I know this for sure, from personal experience.
Old Oct 1, 2007 | 09:21 AM
NICK YOSKIN
St. Jude Donor '08
that is correct.....no matter what itll still go into reduced engine...ok so it doesnt report the code when u read the dtc but whats the difference
Old Oct 1, 2007 | 09:26 AM
NICK YOSKIN
St. Jude Donor '08
Old Oct 1, 2007 | 09:44 AM
RoadRebel's Avatar
RoadRebel
You need more experience. It will do NOTHING to stop the PCM from going into reduced engine power mode in this situation. All it will do it stop the reporting of the DTC but it will still shut down.
Phil
Old Oct 1, 2007 | 10:03 AM
NICK YOSKIN
St. Jude Donor '08
"personal experience"......really
please dont be affended but your completely wrong
To dreaded 1514 code
Old Oct 1, 2007 | 10:48 AM
RJW's Avatar
RJW
St. Jude Donor '08
So Nick.....
Did you get it solved?????
Old Oct 1, 2007 | 10:55 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
youll get it figured out, you always do! I cant figure out if you love that program or hate it
Old Oct 1, 2007 | 11:11 AM
95BlueBomber's Avatar
95BlueBomber
Would a 2or3 Bar setup cure this???
