It would be wise for all to do it..........no hijacks or attacks, period.
If you have issues............start your own thread or better yet........take it off line.
Its not rocket science, Just think of the old pinball machines and their scoring displays. Its the same issue but the PCM doent roll over to zero when it goes 999,999 .
Did you basically multiply the VE by 0.70 and divide the IFR by 0.70? This makes sense to me. Decrease the VE but increase injector flow and end up with the same AFR. Correct?
The way it is worded makes it sound like you would multiply both VE and IFR by 0.70. I would expect that to just make you run very lean.
Have you already changed the 1514/0068 table? If not, then you need to do that first. I never had to modify anything, but I am running a 2-bar tune.
It is completely maxed out. As soon as I am about to hit 2.3 g/cyl the code is thrown and the car goed into reduced power mode. The engine is at 13psi at that point. Everyone on the hptuners forums is claiming to see this as well.
